Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: [FIXED] Maytag MZD2766GE Ice Maker Housing Broken
    Feb 2006
    White Marsh Maryland
    Default [FIXED] Maytag MZD2766GE Ice Maker Housing Broken
    The little motor in the back of my freezer that turns the auger in the ice tray to dispense ice has broken. The housing in the back of the freezer cracked and the gear that turns the auger has fallen into the housing.
    The gear is still working but the housing that the mechanism mounts to is totally shattered. There is nothing for the motor to mount to so the housing needs to be replaced. Is this housing a part that can be replaced? If so, how would I get the part number for it and where should I order it from?
    Here's the parts diagram for the ice maker dispenser housing: 09-Ice Bin parts for Maytag MZD2766GEW - AppliancePartsPros.com
    What # is broken?
    Feb 2006
    That definitely is my ice maker. If you look at part #8. That is the motor that turns the auger in the ice tray. Part #8 mounts with four screws to the plastic tray that the pull out ice tray sits on. That is the part that is broken.
    That plastic housing that the 4 screws attach to that hold the motor is destroyed. It totally cracked and broke. That is the part I need. I don't see a part number on the diagram that you provided for that tray.
    Feb 2006
    Is that whole tray part #20? If it is then that is the part I need. Where can I buy it and what is the part number?
    Ok, yes #20 is what you need.
    Its called an Ice Enclosure, you can order it here:
    Manufacturer part#61005619 is RepairClinic item#901798
    61005619
    Feb 2006
    Jake, that is exactly what I need. That baby got destroyed where the motor mounts to it. I heard that there was a recall on that part at one time. I will get the part ordered. Thank You!
    Ok, sounds good, let us know how it goes.
    Feb 2006
    The mission has been completed. I had to remove the 1/4 inch screw under the tray in order to remove it. Once it was removed all I had to do was swap the screws over and mount the motor onto the new tray. Thanks for your help. Everything is working fine.
    Excellent, good job, glad its working good again.
    Sep 2008
    Florida
    Default Another Ice Enclosure Problem
    I have the same problem with the Ice Enclosure. I've ordered the part and now having problems getting the motor/auger installed. I assume the auger (item #9 on the diagram) unscrews from the motor shaft. I've tried to unscrew it but having difficulty and thought better to ask than to force and possibly break.
    Regards, Sandflea
  1. FIXED: Whirlpool ice maker water fill tube and cup freezing up
    By NDS in forum Whirlpool/Roper/Estate
    Last Post: July 22nd, 2013, 04:12 AM
  2. Ice Maker problem. No ice. Jake?
    By unconventional in forum Sears Kenmore
    Last Post: April 4th, 2008, 08:45 PM
  3. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
    Last Post: February 2nd, 2008, 06:05 PM
  4. Maytag Ice maker odd noise and no ice
    By NorthView Farm in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 27th, 2007, 08:00 PM
  5. Under sink RO to Ice Maker - Maytag Wide-Side
    By isoglut in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 12th, 2007, 12:52 PM
