Results 1 to 5 of 5
Thread: Noisy In Spin Maytag Washer
    Feb 2006
    indiana
    Default Noisy In Spin Maytag Washer
    I Am Working On A Maytag Washer Model Lat9420aae. Complaint Was Noisy Spin And Water Leak At Tub Bearing. I Replaced Mounting Stem And Boot Seal Kit And Tub Bearing. Water Leak Was Fixed. But Machine Is Still Noisy In Spin. I Noticed That Sound Is Coming From Either Brake Rotor Bearing , Radial Ball Bearing Or Possibly Both. I Have Never Replaced A Radial Ball Bearing. Any Tips Would Be Greatly Appreciated.
    Aug 2005
    Milbank, South Dakota
    I doubt the sound is coming from the break on that model.
    Breaks most often are only noisy during the stopping of the spin cycle.
    I would replace that other bearing.
    Yes, I agree with AJ, Its more likely the spin bearing above the brake assembly.
    Here's the one for your model, there's also a link for the brake removal tool:
    Manufacturer part#22003441 is RepairClinic item#893728
    This shows you how to remove the brake assembly:
    Feb 2006
    indiana
    Thanks For The Info It Was The Bearing In The Top Of The Brake Package. Water Had Gotten Into It And Rusted It. That Was A First For Me In Finding This Bearing Bad Thanks For All The Help. Kjr232
    Sounds good, glad you found it was the top bearing above the brake package.
  1. Maytag Performa Washer will not spin
    By jskaldorf in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 18th, 2011, 01:55 PM
  2. Maytag Dependable Care Washer Squeal/Sqweak on Spin Start
    By ggallant in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 9th, 2007, 01:43 PM
  3. Need Ideas For Troubleshooting Noisy Maytag Washer
    By kc27 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 7th, 2007, 03:41 PM
  4. Replies: 5
    Last Post: November 26th, 2006, 10:37 PM
  5. Kenmore HE3T Washer - Noisy Spin Update info
    By carolynnchase in forum Sears Kenmore
    Last Post: May 11th, 2006, 12:22 PM
