Results 1 to 10 of 10
Thread: How can I take off the top and bottom arms?
    Sep 2007
    tulsa, ok
    Default How can I take off the top and bottom arms?
    I have a Maytag MDB7100 and I can see what it looks like in the diagram, but I'm still at a loss for how to remove the top and bottom arm. They are completely plugged up and I need to clean them...
    Alan
    Oct 2004
    MDB7100
    That is part of a full model#.
    Top one, grab ahold of the middle of the arm and yank straight down.
    Lower one, unscrew off the center nut (#34), lift out pop up nozzle (#1) and lift straight up to remove the arm.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Sep 2007
    tulsa, ok
    Thanks, I got the two arms pulled out and they were caked with deposits from hard water. I got both of them mostly cleaned up. When are the arms supposed to move? If I set them into one position and let it run, they stay in the same spot...
    Alan
    Sep 2007
    tulsa, ok
    I put some Dishwasher Magic in it and it is running now. The top arm is now spinning and I can see water spraying all over the place when I open it in the wash cycle, so that is an improvement.
    The bottom arm doesn't look like it is moving to me. Is it supposed to move from the water pressure like the top one?
    Alan
    Oct 2004
    Yes.
    Dig deeper into the pump assy and clean the back flush arm (7) and filter (8).....remove the screws and cover to access.
    Sep 2007
    tulsa, ok
    I had it tore down to part #4. How do I get it off? Do I need to remove that screw #5?
    Thanks for your help, I truly appreciate it!
    Alan
    Oct 2004
    Screws yes. Once screws are removed the cover will lift off.
    Sep 2007
    tulsa, ok
    I got #4 off once I removed the 3 screws and #6 came with it. What about #7? Do I need to remove the nylon torx looking screw to get it out as well?
    Alan
    Sep 2007
    tulsa, ok
    Hi Jeff,
    I got the #4, #6, #7 off and wow what a mess of scale. I used my pressure washer on it (I have found more uses for that thing!) and cleared off all the scale without too much work. I thought the mesh on the top of the filter #4 was some sort of metal so I blasted them with the pressure washer before I realized they were a mesh, but I didn't get any holes in it even though I hit it hard. There are still a couple large pieces of scale that were too big to exit the #4 so I just left them in there for now.
    I put it back together and it sounds like it did when it was new, both arms are going around and water is spraying around in there like crazy.
    Thanks for the help and quick responses, I appreciated it!!!
    Alan
    Oct 2004
    Great
  1. Kenmore (Whirlpool) 665 leaking badly from door bottom
    By tahani in forum Whirlpool/Roper/Estate
    Last Post: November 8th, 2012, 03:09 PM
  2. Arms aren't turning on top or bottom
    By skmcvay in forum Frigidaire/Electrolux
    Last Post: September 9th, 2007, 03:08 PM
  3. Replies: 3
    Last Post: December 14th, 2006, 10:23 PM
  4. Kenmore Refrigerator, frost in the top, drips on the bottom...
    By jbralyATgmail.com in forum Sears Kenmore
    Last Post: August 11th, 2005, 10:31 PM
  5. Replies: 5
    Last Post: July 16th, 2005, 01:28 AM
