Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Ice Dispenser Motor Won't run
    Jun 2008
    Sweet Home Alabama
    Default Ice Dispenser Motor Won't run
    Model Number: GSL25JFPABS
    Brand: GE
    GE Refridgerator Model GSL25JFPABS
    Ice Dispenser Model CAN13 WR30X10093
    When pushing the cubed and crushed door lever with a glass, all I hear is a loud CLICK. The motor does not start and the auger does not turn. I have removed the ice bucket and the auger and the motor drive fork both turn freely. Is the motor toast, the control board, or both? How do I start troubleshooting this? I have a meter and am able to check voltages, continuity, etc. Thanks very much, Don
    Jul 2006
    Hi Don,
    First check the door switch. That's the most common. I'll look for a tech sheet for that model in the mean time.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jun 2008
    Sweet Home Alabama
    Quote Originally Posted by redbeardnmt View Post
    Hi Don,
    Thanks very much for the reply. I can't even get the CLUNK noise (which sounds like a solenoid) with the door open. But when I close the door, I get the sound when I try to get ice, so it seems the switch is makin' and breakin'. It's like a clunk, then a faint humm, like the motor is trying to run but can't.
    Jul 2006
    I couldn't find a wiring diagram for that specific model so I'm going by one that I believe uses the same style dispenser. If you remove the bottom toe plate on your refrigerator, look on the right side and tucked up under there should be your wiring diagram. The best, if not easiest way to check the auger motor is pull it out. It's just four screws, two on each side of the fork assembly. The white plate and auger motor will come out together. There is a quick disconnect for the wires (Pulls apart). Once you have it out, remove the two wires on the motor and connect 110VAC (an old lamp cord with alligator clips works well) If the motor doesn't run, it's bad if it does run then the problem is probably in the dispenser control board. Your wiring diagram will tell you how to check it. It might also be a loose connection back there by the auger motor.
    Also, you could have the motherboard causing this as well as described here:
    http://www.applianceblog.com/mainfor...ead.php?t=7561
    Read post#8 it has a toll-free number you can call to see if you qualify for a new motherboard sent to your house for free.
    Jun 2008
    Sweet Home Alabama
    Thanks guys. I tried calling the GE number to see if my model is covered; nobody is home on Sundays. The serial number of my fridge is HF239488, which does not fall into the range of the covered models it looks like. But I'll try Monday to find out for sure.
    I get the clicking noise when calling for cubed ice only. When the ice tray is pulled, I can see the hole shutter that the sensor (?) rod on the tray goes into opening and closing when I call for cubed ice. This is what's making the clicking noise. When calling for crushed ice, nothing happens. The only thing that dispenses is water. Does this sound like the main board problem? Thanks for all the great help, Don
    Jun 2008
    Sweet Home Alabama
    I pulled the auger motor assembly, disconnected the two spade lugs from the motor, and applied 120VAC to the motor windings. It arced and blew a house 15A fuse.
    The motor windings from end-to-end are also open. Weather this happened during testing or not I'm not sure, but the motor is shot now. Also to the left of the motor there is a solenoid; this is what was clicking when I tried to get cubed ice. Are these motors available by themselves? Thanks very much. Don
    Jun 2008
    Sweet Home Alabama
    The motor name tag states:
    Merkle-Korff
    Part no. 200D1064P004
    Model No. 374UP-440
    Its ok,
    You may just need the motor anyways since the motor windings are open.
    Here's the auger motor for your model you can order:
    Auger Motor WR60X10258 Order now for same day shipping. 365 day return policy. RepairClinic.com
    The solenoid should be ok, it moves up for cubed ice. You can test it with the ice bucket out to see.
    Jul 2006
    That happens sometimes. I should of warned you. The winding wire burns out close to the connection. When you put the cord on to test it, it moved the wire strand where it made a connection or short to a closer strand. Instead of going through the entire coil of wire, it probably went through just a couple turns. Just like putting the two ends of the power cord together then plugging it in. I'm sure that was the problem with the motor.
  1. Replies: 1
    Last Post: February 28th, 2013, 09:59 PM
  2. FIXED: Auger Motor In Ice Dispenser Does Not Run
    By Diy Richard in forum KitchenAid
    Last Post: October 6th, 2012, 01:21 PM
  3. Ice Dispenser Motor not turning
    By jfay in forum KitchenAid
    Last Post: July 23rd, 2011, 04:07 PM
  4. Replies: 1
    Last Post: June 13th, 2010, 11:10 AM
  5. GE GSS22WGMD Ice Dispenser Motor
    By bernball in forum GE/Hotpoint
    Last Post: January 15th, 2009, 11:17 PM
