Social Buttons
Results 1 to 10 of 11
Thread: Another Whirlpool 365
    Jun 2008
    Maryland
    Default Another Whirlpool 365
    I tried a search and couldn't find an answer,,
    I have a WP 365
    Model SF370LEGN
    Ser. RJ1212113
    Oven not working, the glow bar glows fine but it seems no gas.
    Display, good, temp and warmup countdown, good
    Stove top good
    Broiler good
    I looked at the "direct ignition" manual,, but mine has glow bar.
    I have multimeters ect so any diagnostic help would be appr.
    Tom
    Jul 2006
    Murray, Utah, United States
    Look on the oven safety valve for an amp value. Use a clamp type amp meter around one of the ignitor wires. It needs to pull that many amps to open the safety valve. I'm not sure but I think it's like 3.1 to 3.3 amps. Anything less, replace the ignitor.
    OWNER RICK'S APPLIANCE REPAIR
    APPLIANCE TECHNICIAN FOR 29 YEARS
    REFRIGERATION SPECIALIST
    Jun 2008
    Maryland
    Hmmm,, couldn't find value on safety valve,, but found this in manual-----
    Lower ignitor resistance increases the current flow through the bimetal coil. When the ignitor is fully
    heated, its resistance is low. Low resistance causes maximum current to flow through the bimetal
    coil (2.5 to 3.6 amps).-----
    Mine peaked at 1.68a,,, (even though it glows bright orange) guessing thats the issue huh?
    Going to order the ignitor.
    Tom
    Jul 2006
    Yep, Replacing the ignitor should fix the problem.
    Jun 2008
    Maryland
    Can I swap the Broiler to the oven untill the ignitor gets here? Wife uses the oven very often,, broiler rarely.
    Tom
    Jul 2006
    Yes, there shouldn't be any problems. They are the same ignitor.
    Here's the oven/broiler igniter for your model, in case you ever need to order it:
    Manufacturer's Number: 4342528
    Jun 2008
    Maryland
    Igniter came today,, problem solved!! Thanks for the great site and help!!
    Tom
    Excellent, good job Tom fixing it.
    Jun 2008
    Maryland
    The credit goes to redbeardmt, I figured if the igniter was glowing as bright as it was that it would be good. But i doubted the valve was the problem as the broiler worked.
    Tom
  1. Whirlpool Duet is a Nightmare!
    By CheerMom in forum Whirlpool Reviews
    Last Post: October 18th, 2010, 12:54 PM
  2. Whirlpool du1148xtpqa dishwasher sensing won't work
    By dmello1284 in forum Whirlpool/Roper/Estate
    Last Post: August 22nd, 2007, 12:49 PM
  3. Whirlpool WED9400S Drum Light
    By nanook in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 28th, 2007, 08:55 PM
  4. Done with Whirlpool & Kenmore Beyond Lemons
    By automan1223 in forum Sears Kenmore Reviews
    Last Post: March 3rd, 2007, 01:57 PM
  5. Kitchenaid vs Whirlpool?
    By rv8 in forum KitchenAid
    Last Post: January 26th, 2006, 02:22 AM
