Results 1 to 6 of 6
Thread: Thermal Fuse on 665.17579201
    Aug 2006
    Bel Air, MD
    Default Thermal Fuse on 665.17579201
    Model Number: 665.17579201
    My dishwasher will not do anything at the moment. I'm fairly certain my thermal fuse needs to be replaced. I measured 120V at the input, but only millivolts on the output.
    I see that the original part number 9269213 has been replaced by a new part number 8193762. It appears to come with a new harness, which from what I've read, should always be used. I don't have the kit yet, so maybe this will become clear once I have it, but I don't see any interconnects in my current wiring. I have a main that comes up, and it splits with one going to the fuse and the other to the control board. Here are a couple of links to the new part. Does the kit come with all I need to splice this into my current dishwasher?
    Thermal Fuse 8193762 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Thanks in advance for your help.
    Ned
    Hi Ned,
    When its completely dead like that, then its likely your thermal fuse.
    You can ohm it for continuity with a multimeter to see if it has no continuity. Thats what I always do.
    Here's the thermal fuse for your model below.
    That wiring that comes with the new thermal fuse kit MUST be changed for it to work properly, or it will keep blowing that fuse forever.
    Here's the video:
    Aug 2006
    Bel Air, MD
    Thanks for the quick reply. I'll be picking up the part tomorrow, and installing it after work. I'll post again after that.
    Sounds good Ned.
    Aug 2006
    Bel Air, MD
    All is well after replacing the thermal fuse.
    Excellent, good job fixing it Ned.
  1. Not thermal fuse, now what?
    By tgregg76 in forum Sears Kenmore
    Last Post: August 4th, 2014, 11:31 AM
  2. Thermal fuse
    By lvsloan1 in forum Whirlpool/Roper/Estate
    Last Post: October 16th, 2013, 07:44 PM
  3. FIXED: Blew thermal fuse, again
    By ed77901 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 16th, 2013, 03:56 PM
  4. thermal fuse
    By jimh80 in forum Sears Kenmore
    Last Post: September 3rd, 2012, 07:45 PM
  5. Thermal Fuse Fix
    By acspectrum in forum Whirlpool/Roper
    Last Post: April 15th, 2011, 03:07 PM
