Results 1 to 8 of 8
Thread: Kenmore Elite 110.85876400 - Dead Front Panel ?
    Jul 2008
    Texas
    Default Kenmore Elite 110.85876400 - Dead Front Panel ?
    Kenmore Elite Model# 110.85876400 (HE4, Electric, Smartheat, made by Whirlpool)
    Here is my problem (just started out of the blue one day)
    The front control panel (with all the buttons for settings) is totally dead --
    Normally, numerous red lights come on when pressing buttons -- now its nothing when I hit the buttons.
    The lightbulb inside the drum is working fine when I open the door (and goes out when I close it, like usual).
    I've checked my house breakers (2 of them) and both are OK. I even turned them on and off a couple of times.
    This unit is only about 2 yrs old - just old enough to be out of warranty
    Any ideas on how to troubleshoot ? I can't even figure out how to open the panel - its the newer dryer with the circular opening (front load) -- the panel seems to be flush with the body and no obvious screws etc to open it to see anything.
    Any help is appreciated!
    thanks.
    Here is the online repair manual for the Kenmore HE4/Duet dryer:
    https://secured.whirlpool.com/Servic...LE/Duetdry.pdf
    Give it time to download.
    I'm attaching the simplified diagnostics sheet below(Page 10 tells how to take the bottom panel off):
    Page 8 has the button & LED test.
    Attached Files Attached Files
    Jul 2008
    Texas
    Jake:
    Thanks for the links. I'll open up the dryer today and see what I can find based on the docs you posted.
    I'll post here the results or if I run into trouble with anything while trying to do it !!
    Sounds good, let us know what happens.
    Jul 2008
    Texas
    Default Initial testing results ....
    I tested based on the diagnostics sheet (pg 8) -- about half of the buttons did not generate a reading on my multi-meter - the other half did show some reading when pressed.
    I assumed the black wire was position "1" (in the 1-14 pins).
    Does that mean the console/button board needs replacement? Is it common for some buttons to respond to the test, while others dont ?
    Just want to be sure I was measuring it correctly.
    Yes, it sounds like you'll need to replace your control panel assembly.
    Here's the control panel for your model:
    Whirlpool 280087 Cntrl-Elec - AppliancePartsPros.com
    The repair manual I posted a link to above shows you how to replace it.
    Jul 2008
    Texas
    Thanks for the link.
    Also I tested it using the exposed wire on the side of the cable connector (not on the end - the part that plugs in) -- would that make a difference ?
    (my probe lead was too thick to go into the actual "holes" on the pin)
    Does this site have any warranty for the part ? Is this part prone to failure?
    thanks
    Yes, the way you tested it was fine.
    It comes with a special 365 day full refund if you install it and it doesn't fix the problem.
  1. Kenmore Elite HE3T ( 110.42926200 ) dead
    By Shockdaddyd in forum Sears Kenmore
    Last Post: June 25th, 2007, 10:48 AM
  2. Kenmore Calypso 110.22082102 front panel is dead
    By abes1 in forum Sears Kenmore
    Last Post: December 5th, 2006, 11:02 PM
  3. Kenmore Elite 665.17462300 keypad panel
    By rleist in forum Sears Kenmore
    Last Post: September 7th, 2006, 12:07 PM
  4. Kenmore Elite 110.63932101 Back Panel Off?
    By jbell44 in forum Sears Kenmore
    Last Post: August 24th, 2005, 09:41 PM
  5. Dead Kenmore Elite dryer
    By dbhovel in forum Sears Kenmore
    Last Post: December 16th, 2004, 07:14 PM
