Results 1 to 2 of 2
Thread: Jenn-Air Convention Double Wall Oven (WW30430B) - F1 Error
    Jul 2008
    Mandeville, LA
    Default Jenn-Air Convention Double Wall Oven (WW30430B) - F1 Error
    I have the Jenn-Air double convection wall ovens, model number WW30430B. The lower oven has just started displaying an F1 error code along with almost constant beeping. First, can you please tell me how to make this beeping stop? It's driving me CRAZY!
    Second, do you know what is causing this error? If so, is it an easy fix? The ovens are 11 years old and I would rather replace them if the repair is expensive.
    Thank you so much for your help.
    ~Rozanne
    Hi Rozanne,
    You would need the lower relay control board and the membrane switch. These are expensive parts, so I'd advise to save the repair money for a new double oven.
    Here's the lower relay control board for your model:
    Manufacturer part#12001914 is RepairClinic item#958653
    12001914
    Here's the membrane switch:
    Manufacturer part#71001873 is RepairClinic item#695198
    71001873
  1. FIXED: Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: November 11th, 2013, 07:31 AM
  2. whirlpool double wall oven doesn't work
    By Barreras in forum Whirlpool/Roper
    Last Post: October 9th, 2008, 10:19 AM
  3. Jenn Air wall oven W304008 wont turn off
    By sun45 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 3rd, 2008, 09:02 AM
  4. Frigidaire Double Wall Oven or Repair Existing GE Wall Unit
    By knittermom in forum Frigidaire/Electrolux Reviews
    Last Post: February 8th, 2007, 11:39 AM
  5. Jenn Air Wall Oven With Fault Code 1
    By AFH in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 3rd, 2006, 11:52 AM
