Results 1 to 6 of 6
Thread: Door Ice Maker Not Dispensing
    Jan 2008
    Houston
    Default Door Ice Maker Not Dispensing
    Model Number: GS6SHAXMB00
    I have a Whirlpool Conquest SxS which recently refuses to dispense any ice. There is no sound when the ice dispenser lever is actuated. The water dispenser works fine.
    I used the in-door ice system manual so graciously provided by this forum but I've noticed some discrepancies between the manual and my ice system. Suspecting that the dispenser motor may be faulty, I removed the panel and discovered that while the manual indicates 5 or 6 wires going to the motor, mine only has four. The wiring is as follows...
    Pin Color
    1. Brwn/Wht
    2. Red/Wht
    3. nc
    4. nc
    5. Gray
    6. nc
    7. Blue
    I get 115VAC when measuring between the Blue and the Gray (pins 5 & 7) when the ice lever is pushed but I get a DC voltage which jumps around .5 VDC and 2.3VDC on pins 1&2.
    Does this sound like a bad motor? Also, where is the rectifier located?
    Thanks for any help you can offer,
    Robert
    Hi Robert,
    Here's the data sheet on your electronic dispenser:
    http://adcxns1.whirlpool.com/Service...24-27_UD24.pdf
    Jan 2008
    Houston
    This diagram makes a lot more sense. Let me see what I can do with this.
    Ok, sounds good, let us know how it goes.
    Jan 2008
    Houston
    Hi Jake: Motor was just frozen. A quick thaw and a drying out solved the problem. I have ice through the door again;-)
    Thanks again,
    Robert
    Good job Robert.
    Here's the ice dispenser motor for your model, in case you need to order it:
    Whirlpool 2252129 Dispenser, Motor - AppliancePartsPros.com
    2252129
  1. Maytag French Door Icemaker, maker is working but not dispensing
    By mjaski in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 18th, 2013, 09:37 PM
  2. Replies: 15
    Last Post: February 18th, 2013, 05:22 PM
  3. Not dispensing ice through door
    By aero993 in forum Frigidaire/Electrolux
    Last Post: November 20th, 2011, 10:42 PM
  4. Ice maker not dispensing ice
    By remmi in forum Whirlpool/Roper/Estate
    Last Post: May 2nd, 2011, 07:35 PM
  5. In Door Ice maker not dispensing ice
    By mscott327 in forum Whirlpool/Roper/Estate
    Last Post: December 23rd, 2010, 10:13 PM
