Results 1 to 9 of 9
Thread: Kenmore range - dim display
    Oct 2006
    chicago
    Default Kenmore range - dim display
    I've had a Kenmore gas range for about 5 years now, and the LED display is really getting dim. If the oven is on, I can barely read what the temperature is (the "red" lettering.) The green LED is a little better, but dim also. When everything it turned off, and only the clock is on, it is easy to read. But when the oven is on, it's all pretty dim. Any suggestions?
    Yes,
    You'll need a new electronic clock assembly control board.
    Whats the model# of your range?
    Oct 2006
    chicago
    Thanks for getting back to me so quickly!
    The range (i believe) is model no. 665.75012. This is according to what someone wrote on the back in Sharpie marker. The manual covers a pretty wide range of ranges (pun intended) from 665.72002 to 75849. Let me know if you need any further info.
    That model# doesn't pan out.
    Your model# tag is located at the bottom front of your range on the front left or right side frame after you pull your storage drawer out.
    Oct 2006
    chicago
    Left side
    Mod. # 665-75012101
    Ser. # RL3914388
    Oct 2006
    chicago
    Thanks, that model# is good.
    Yes, thats the correct control board.
    Oct 2006
    chicago
    But for now, I think I'll just count the "beeps" up from 350 degrees, and use one of these:
    http://www.bedbathandbeyond.com/prod...2&SKU=10161738
    Ok,
    Here's a more accurate one you can order:
    Polder Cooking Thermometer with Timer and Clock
  1. Whirlpool RBD305PRB Double Wall Oven Display Dim
    By mangowhirlpooltango in forum Whirlpool/Roper
    Last Post: March 11th, 2008, 12:04 AM
  2. Kenmore slidein range installation problem
    By thulb in forum Sears Kenmore
    Last Post: November 21st, 2007, 12:41 PM
  3. Kenmore gas range "PF" display
    By kenandcar in forum Sears Kenmore
    Last Post: December 13th, 2006, 08:31 PM
  4. Kenmore 665 range no display, but burners ok
    By frd1963 in forum Sears Kenmore
    Last Post: July 21st, 2006, 01:57 AM
