Results 1 to 4 of 4
Thread: Amana side by side sxd23ve evap fan
    Aug 2008
    akron ohio
    Default Amana side by side sxd23ve evap fan
    I have a sxd23ve that frosts up.. The evap fan has a set of brown wires going to it. which seems to be a neutral. I only get about 60 volts to the fan.. but when I run a neutral dirctly to the terminal where the brown wires land the fan runs with 120v. To make this worse it is intermittant. where do the brown wires come from or goto?
    one goes through the defrost switch while the other hits the evap fan. when the circuit is good the heater works and the fan works.
    thanks
    It sounds like possibly either your defrost thermostat is starting to malfunction, that would cause the evaporator fan not to run properly and drop voltage.
    You can get an ohm meter to check continuity on your defrost thermostat(while its frosty).
    Here's the defrost thermostat for your model:
    Defrost thermostat with wire harness, clip-on, L48-33 degrees
    (The manufacturer has replaced part number 12017823 with this item, part number R0161088.)
    Its located on your evaporator coil on the top, it just clips on.
    Aug 2008
    akron ohio
    you are the man
    thanks again
    Glad you got it fixed.
  1. Amana Evap Fan Motor
    By sandboe in forum Amana
    Last Post: April 23rd, 2008, 01:47 PM
  2. Replies: 3
    Last Post: November 26th, 2007, 08:56 PM
  3. GE Freezer -evap motor fan?
    By redlady4850 in forum GE/Hotpoint
    Last Post: November 11th, 2007, 02:41 AM
  4. Amana side by side not cooling (much)
    By ajohnson in forum Amana
    Last Post: December 8th, 2006, 12:09 PM
  5. Another Defective Amana Side by Side
    By PCourts in forum Amana
    Last Post: November 12th, 2006, 01:24 AM
Tags for this Thread
