Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Whirlpool Icemaker leaking
    Aug 2008
    Cincinnati, oh
    Default Whirlpool Icemaker leaking
    We have a Whirlpool refridgerator/freezer (model# ED5HLAXMQ10) that is 3 1/2 years old. It is a side-by-side model. Recently it is producing a constant water drip into the ice maker and the drip won't stop. The ice maker will fill up and make cubes, but the water keeps dripping into the ice maker and causes a huge mess.
    When we turn the main water supply line off, the drip stops. But when the water supply is back on, there is a drip that keeps coming from the black spout inside of the freezer. This will keep dripping into the ice maker even when the ice maker is full.
    The ice maker appears fine. I think there is some problem in the water line and black spout. I have tried to take the black spout off, but it seems like it is attached and there doesn't seem to be a way into check on it any other way.
    Is this an easy fix or will we need to have someone come out? We're complete novices, but this is the 3rd time this ice maker has had a problem & we're hoping to be able to fix ourselves since it is so expensive to have someone repair.
    Thanks in advance.
    Carrie
    Hi Carrie,
    Please double check your model#, That one doesn't show as good.
    Sounds like your water inlet valve is bad. Once I have your correct model# I'll find the cheapest one you can order.
    Aug 2008
    Cincinnati, oh
    Sorry - it's model# ED5LHAXMQ10.
    Is it fairly simple to replace?
    Yes, its easy to replace, just pull your refrigerator out from the wall, turn off your water supply to the refrigerator, take off the water supply line connector, unmount the water inlet valve from the refrigerator cabinet, take off the electrical connectors(mark down were they go first) then take off the tubing(also mark were they go) then install the new water inlet valve.
    Here's the one for your model you can order:
    Manufacturer's Number: 4389177
    4389177
    Aug 2008
    Cincinnati, oh
    Thumbs up
    Thanks a million - you are the BEST!!!
    We hooked it up & it is working - saved us a good chunk of change!!! I'm so glad we found your site!
    Thanks again!!!
    Excellent, good job fixing it Carrie.
    Oct 2010
    cincinnati
    Default I have same issue
    I am having the same issue. If i lift the lever on my icemaker to turn it off it does not leak. Otherwise it drips and leaves and icy mess in my freezer.
    model GR9SHMXKQ01
    Ok, in your case its a little different, when you lift the arm that just turns the ice maker off, thus no water leak since its not ON and cycling to make ice. If it still leaked with the arm up, then you'd need the water inlet valve as above member Carrie needed.
    After time the ice maker will start to LEAK due to wearing of the circuit board contacts, WHEN its ON and the arm is down.
    A new ice maker will fix it.
    Here's the Ice Maker for your model you can order here:
    Manufacturer's Number: 4317943
    4317943
    Oct 2010
    cincinnati
    Is that the only thing it could be? It was working fine until one of my family accidentally turned it off. I forgot about the arm being the on/off switch and jiggled some things.
    I do appreciate your quick reply Jake.
    Yes, thats basically all it can be.
  1. Another Whirlpool Icemaker Problem
    By BCB in forum Whirlpool/Roper/Estate
    Last Post: August 24th, 2015, 07:26 AM
  2. Icemaker Failure. Whirlpool Conquest GS6SHAXKS02.
    By GaryGershzohn in forum Whirlpool/Roper/Estate
    Last Post: July 1st, 2010, 11:49 AM
  3. Frididaire side x side -- Icemaker leaking
    By 5chandlers in forum Frigidaire/Electrolux
    Last Post: September 14th, 2007, 10:22 PM
  4. Another Whirlpool Gold Icemaker gone bad...
    By Traveler999 in forum Whirlpool/Roper/Estate
    Last Post: June 28th, 2007, 04:40 PM
  5. Whirlpool icemaker
    By ApolloBSG in forum Whirlpool/Roper/Estate
    Last Post: February 23rd, 2007, 01:57 PM
