Results 1 to 6 of 6
Thread: Maytag Neptune MDE3000AYW too hot
    Aug 2008
    USA
    Default Maytag Neptune MDE3000AYW too hot
    Lately my dryer has been getting way too hot on any cycle or setting i put it on. I tried air fluff and it was still getting things too hot. A few people suggested that i check for an obstruction so i took it appart and found that the boot going to the motor from the lint catcher duct had fallen half way and was blocking airflow. While i was in there i did a very thorough cleaning. Everything went back together fine and it opperated smoothly after it was together. But it was still overheating even on a fluff cycle.
    Could one of the two thermostats be doing this if it were broken and needed replacing?? Could it be the temp selector on the control pannel? I would think on an air fluff setting it wouldnt even turn the heater on.
    Here's the heating element parts diagram:
    It sounds like your heating element#5 is grounding to the heater housing tube#3. Something may have gotten in the tube and causing it to ground and stay on continuously.
    Unplug your dryer and check the element.
    Here is the heating element assembly for your model:
    Manufacturer Number 307178
    Aug 2008
    USA
    So i took it back appart. More than i was comfortable with but i figure it had to be done. You were dead right it was the heater that had touched the outside and grounded itself. Look at the last pic. I also did a descent cleaning on this unit. Cant go airing my dirty laundry all over the internet. (Budump- tsss)
    2000 Ford Mustang FOR SALE in central Florida.
    http://www.allfordmustangs.com/pp-cl...p?product=9445
    Excellent, good job finding that the element wire was touching the heater housing.
    Aug 2008
    USA
    Is there a recomended break in procedure for the new heating element. I thought id run it empty for 20 min on medium heat. Just to get that new equipment smell out.
    Not in particular, but 20 minutes break-in time should be fine.
  1. Maytag Neptune...should I buy it?
    By Klute in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2010, 07:23 PM
  2. Maytag Neptune 8700 repair issues & Maytag Rant.
    By jazzman_q in forum Maytag/Jenn-Air Reviews
    Last Post: May 19th, 2009, 11:40 AM
  3. maytag neptune mde3000ayw major rumble going on
    By marcey in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 23rd, 2008, 12:18 AM
  4. Maytag Neptune - Too Hot!
    By jodygo in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 4th, 2008, 09:49 AM
  5. Maytag Neptune - No spin cycle
    By fox_1028 in forum Maytag/Jenn-Air Reviews
    Last Post: May 24th, 2006, 11:15 AM
