Results 1 to 2 of 2
Thread: JennAir JDS9860AAB F1-7 Code
    Sep 2008
    awendaw
    Default JennAir JDS9860AAB F1-7 Code
    I have read through the threads about this prblem, but I am confused about the difference between a control panel and a clock panel. We had a power failure last night for an hour and this afternoon our range let out several beeps. Knowing my wife can't cook and never uses the range ~ I went to look at it. It read a F1-7 code. I shut the power and turned it back on, same thing. I pressed all the buttons on the key pad and then it read a F1-8. When I cut power again and then restored, it read an F1-7. It is a JDS9860AAB Serial # 13969323ZM Which part do I buy?
    The touch panel membrane is just the buttons you press for the operating of it. The control board is the brain.
    Here's the touch panel membrane for your model:
    Manufacturer part number 74005750 is RepairClinic item number 895133
    74005750
    Here's the tech. data sheet for your model:
    http://www.servicematters.com/maytag...s/16026780.pdf
    F1-7 Membrane disconnected.
    Ensure ribbon cable is securely connected, inspect
    ribbon cable and connector (shorts, breakage,
    corrosion, etc.). If OK, replace control.
    F1-8 Shorted key (pad) in membrane switch.
    Manufacturer part number 74006363 is RepairClinic item number 895712
    74006363
  1. KitchenAid Range Error code F1:E3
    By Katy in forum KitchenAid
    Last Post: February 12th, 2011, 11:51 PM
  2. Gemini MER6769BAW Error Code F1-8
    By MarkP in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 11th, 2008, 12:01 PM
  3. FEF388WCCD locked up with F3 trouble code
    By stewarttate in forum Frigidaire/Tappan/Electrolux
    Last Post: November 22nd, 2006, 11:45 PM
  4. Jennair oven trouble
    By danstatz in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 17th, 2006, 12:34 PM
  5. Jennair - too high temp - F1 fault code
    By tonypete in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 3rd, 2006, 07:30 PM
