Results 1 to 8 of 8
Thread: Kenmore 106.55603400 Ice Maker
    Sep 2008
    Arizona
    Default Kenmore 106.55603400 Ice Maker
    I've read several similar problems. My ice maker stopped with ice in the tray. I tried defrosting to clear the filler line. I tested the solnoid with an ohm meter which looked OK at 235. The claws now rotate to dump the ice, but no water is filling in the tray which sounds inconsistent with the initial state. The lights seem to be working OK also.
    Can you suggest the failing component or course of action for remedy?
    Thanks...
    Did you read this thread:
    http://www.applianceblog.com/mainfor...ead.php?t=1688
    Does the LED light stay steady ON?
    What position are the ice maker ejector finger at now? Pointing at you?
    Sep 2008
    Arizona
    Yes, I read about the blinks. I have:
    - 2 blinks when door is open
    - 1 blink when claw is turning
    - The claw stops pointing towards me with a slight up-slope and steady light with flapper depressed.
    I'll review the manual mentioned in the post you pointed me to.
    Ok, Then it sounds like you may have an ice clog in your black rubber fill tube just above your ice maker that comes down from your freezer ceiling.
    You can use a turkey baster or an ear wax removal kit bulb:
    Shoot it up in that black rubber spout, get a pan or something to catch the water that falls back.
    You'll need to remove your ice maker to get good access to it.
    To remove your ice maker, read post#10 here:
    http://www.applianceblog.com/mainforums/showthread.php?t=3003
    Sep 2008
    Arizona
    Unhappy Unexpected results
    I tried thawing the fill line and made a splice at the back of the freezer. It did not seem to be frozen as expected. I was able to blow air through the fill line. Note that no water has been released above the new splice since I made it.
    I also tried testing the optics and using a jumper on T & H. At that time the location of the fingers changed and the LED blinking also changed.
    The fingers now come to rest at about 5 oclock, nearly straight down.
    The LED was giving erratic blinks of two long and a short repeatedly.
    The LED has gone back to either two blinks or steady. It no longer gives a single blink as it did earlier.
    Does this change in observations make any sense to you? It seems confusing and frustrating to me...
    Yes,
    Its sounding more like your ice maker itself is malfunctioning.
    Here's the ice maker for your model you can order:
    Complete icemaker assembly
    Manufacturer's Part#: 2198597
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 30 day full refund when you return them.
    Sep 2008
    Arizona
    Smile Thanks
    I replaced the ice maker as suggested and it resumed normal operation immediately. Thanks for the help...
    Excellent, good job fixing it.
  1. FIXED: Kenmore Coldspot Ice Maker Stopped Working
    By Izumino in forum Sears Kenmore
    Last Post: June 27th, 2014, 10:55 AM
  2. Kenmore Elite 106.70202990 Ice Maker Problem
    By ckwfly in forum Sears Kenmore
    Last Post: November 2nd, 2011, 09:53 PM
  3. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 12:56 AM
  4. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
    Last Post: February 2nd, 2008, 05:05 PM
  5. Kenmore Ice Maker not dispensing ice.
    By MaryK64 in forum Sears Kenmore
    Last Post: November 23rd, 2007, 09:46 PM
