Results 1 to 4 of 4
Thread: GE Range:Replace oven door glass?!
    Sep 2005
    Georgia
    Question GE Range:Replace oven door glass?!
    I have the GE JCSP31WWWW electric slide in range. I bought it used for a rental property. While moving it into the house the oven door opened and the glass shattered. Now that I have researched this model, I discovered it's not uncommon and GE has now changed the model slightly but takes no responsibility for this dangerous flaw.
    I ordered the replacement glass but got no instructions on how to install it. One would think with the pre-existing handle and the empty door you could figure it out. No such luck. The hardware provided differs slightly(I imagine this is the solution to prevent the new $135.00 glass from breaking).
    Anyone ever do this or know how or know where to find a diagram? I've had no luck but did discover this site so at least one good thing.
    Any suggestions greatly appreciated. Thanks.
    That model# is close but didn't match, these 3 come up:
    JCSP31WW1WW
    JCSP31WW2WW
    JCSP31WW3WW
    Sep 2005
    Georgia
    Default Correct Model #
    The model number directly from the stove is JCSP31GP2WH. The diagram I find at www.partselect.com is an accurate representation of what has been sent to me but it is not exactly what came off the stove when the glass shattered. The assembly I received will not mount in the frame without removing parts that are welded on.
    Thanks.
    Thats a good model#, I have replaced a glass on this oven door before, its very difficult on this model, i would suggest help on this from a local appliance tech.
  1. FIXED: Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: November 11th, 2013, 07:31 AM
  2. Replies: 5
    Last Post: March 16th, 2011, 01:19 PM
  3. FIXED: Whirlpool SF395LEEQ0 - Oven not lighting
    By newdy22 in forum Whirlpool/Roper
    Last Post: April 30th, 2008, 01:33 AM
  4. Jenn-air wall oven doesn't close & temperature is off
    By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 2nd, 2007, 11:14 AM
  5. Amana Oven Slow To Preheat
    By scanor in forum Amana
    Last Post: November 7th, 2005, 08:57 PM
