Page 1 of 8 123 ... LastLast
Results 1 to 10 of 77
Thread: Testing ice maker water supply at the solenoid
    Jan 2009
    Potomac, MD
    Default Testing ice maker water supply at the solenoid
    Model Number: 106.56536400
    Thanks to Jake's prompt response and his instructions on how to test my problematic ice maker, I figured that I'd take some pics and do a How-To to help out the next guy.
    My Kenmore fridge is model # 106.56536400
    My ice maker is model # 106 636663
    I have in-door water, so I have a dual water inlet valve.
    This procedure will work for Kenmore 106.56536400. It will likely apply to others, but I can't say for sure, so my steps apply to this particular model.
    It isn't necessary to turn off the main water supply, or the supply to the fridge; and disconnecting water lines isn't necessary.
    This procedure requires connecting the supply solenoid to 120v wall current using a 'cheater' power source. If you are uncomfortable doing this, or you're working in less-than ideal conditions, please don't attempt this. If your model is different from mine, please confirm that this is an appropriate test before doing it!
    You'll need to get behind your fridge with enough space to access the water inlet valve which is located at the base of the chassis - right or left side(looking at it from the back of your refrigerator). The ice maker can be installed, or it can be out for this procedure.
Name:	water supply 002.jpg
ID:	23983 Click image for larger version.
Name:	water supply 004.jpg
ID:	23988 Click image for larger version.
Name:	water supply 005.jpg
ID:	23989 Click image for larger version.
Name:	water supply 006.jpg
ID:	23990 Click image for larger version.
Name:	water supply 008.jpg
    You'll need:
    • A 'cheater' power plug, which is a wall plug with alligator clips attached to each wire on the other end. I was able to make a safe, solid connection using stripped wire ends, however.
    • A 1/4" socket or wrench
    • A cup to catch the water if your ice maker is removed
    Pull your refrigerator out from the wall then:
    1. Remove the screws that hold the cardboard dust cover, and remove the cover.
    2. Locate the water inlet valve, located at the base of the chassis on the right or left side(looking at it from the back of your refrigerator).
    3. Remove the two screws securing the water inlet valve to the chassis (see 1st pic)
    4. Pull the water inlet valve outward so that the power plug connectors to the solenoids can be accessed.
    5. Identify the correct water inlet valve solenoid for the ice maker. This is the solenoid over the thinner feed line (see 3rd pic)
    6. Remove the plug-in power connector for the ice maker water inlet valve solenoid.
    7. Using the unplugged 'cheater' power plug, clip a wire onto each spade terminal, or thread each stripped wire through the spade holes. (see 4th pic) Ensure that these connections are secure, don't have a chance of touching each other, and are away from the chassis of the fridge. Putting some electrical tape around each is a good preventative measure.
    8. If your ice maker is removed, place a cup, can or small bowl under the black supply hose located above the ice maker on the right side.
    9. Briefly plug in the 'cheater' power cord for 2 seconds or so and listen for operation of the solenoid. If it's operational, it will be clearly heard. Unplug the 'cheater' cord.
    10. Check the catch cup/can for water, or your ice maker tray for water.
    11. If you hear the solenoid after plugging in, but no water comes through the water inlet valve, you have a physical blockage in your line (possibly frozen or clogged). If you don't hear the solenoid after plugging in the cord, it's a bad water inlet valve.
    Hope this helps!
    Feel free to suggest changes/corrections.
    Excellent instructions jptl.
    I will add here how to remove the ice maker assembly:
    Whirlpool 2198597 Complete Icemaker Assembly (8 Cube) - AppliancePartsPros.com
    Here's the video TO remove the ice maker assembly:
    You can buy a test(cheater) cord here:
    Test Cord - 110 Volt With Alligator Clips
    OR you can get a cheater cord like this at any hardware store in your area if you don't want to wait on ordering it.
    Apr 2009
    arizona
    Default Did the test, water works, now what
    I did the test on the inlet valve and the water started right up. Now what, Does that mean everything is working and it is the icemaker that is broken or clogged or something?
    Quote Originally Posted by pstockwell View Post
    Whats the model# of your refrigerator? The model# tag is located inside the refrigerator section on the upper walls or ceiling.
    Even though your water inlet valve checks good, your fill tube that puts water in your ice maker may be clogged.
    Does your ice bucket sit on the inside freezer door? If so look above your ice maker for a black rubber spout that comes down from your freezer ceiling, that may be clogged with ice, try to run something up in there to see.
    Jan 2009
    Potomac, MD
    PStockwell, I'm going to venture a guess here and say that it's a model similar to mine & that it has the same - or similar ice maker system & module....that's probably what got you to this thread.
    When my ice maker stopped working, I had come across numerous "fixed" follow-ups in which the culprit was a bad module.
    However I wasn't going to jump to that conclusion. I'm mechanically stubborn and I wanted to eliminate all possibilities. With Jake's direction, I decided to properly troubleshoot my icemaker. This involved the solenoid test that you just went through, which in turn confirmed that my water line wasn't frozen. That left the module. At least I took some comfort in ruling out a bad solenoid...but my test wasn't necessary. In fact I'm guessing that few solenoids are bad in these cases. Jake, please correct me if I'm wrong here.
    So, in my case it was in fact a bad module.
    Mr. Stockwell, be prepared to install a new module...and take comfort in the fact that you've ruled out all other possibilities.
    The reason that I'm saying this is it's clear that there's a design defect in the modules that were used in various brands over the past few years. I'm really hoping that the thousands of replacement modules have a revised design, or else we'll all be back to buying new modules in the next few years.
    When my father-in-law was complaining last week about not having any ice in his 2 year old Whirlpool, I said "Let me guess....removeable ice compartment in the door". "Yup. How'd you know?"
    I took a look at it, and it was nearly the exact maker to the one in my Kenmore. I said "It's a bad module. Order one and I'll put it in."
    Although the solenoid test is the proper way to rule out a water feed problem, these particular modules are so problematic that I just had him order a new module. When it came, I installed it in all of 10 minutes, and voila! A working ice maker. I impressed the hell out of him, as I clearly knew what I was doing.
    Well, I had a good teacher (thanks again, Jake.)
    Apr 2009
    arizona
    Default Ice Maker Module
    The model # is KSCS25INSS00 kitchenaide. I did the water test and water came out the black spout inside the freezer so that is all good. Is it the module that sends the electrical signal to the inlet valve that it is time for more water? I am moving on to the module (Ice Maker, right?) tomorrow and removing it from the freezer to see if anything is clogged. I hear it spinning once in a while, but who knows at this point.
    JPTL, I appreciate your input and you are right, I am just trying to be as methodical as possible to rule things out before I take the $90 plunge... When you say module you mean the ice maker compenent, right?
    I will follow the instructions of how to remove the ice maker and see what is going on.. I look forward to hearing your answers to my questions and appreciate the help...
    Yes jptl, your right on the money!
    Its likely the ice maker module pstockwell.
    Here's the ice maker module kit for your model, in case you don't want to order the complete ice maker assembly:
    Whirlpool 8201515 Icemaker Motor Module - AppliancePartsPros.com
    Apr 2009
    arizona
    Default Maybe last question
    Even though I have a kitchenaide I can use the whirlpool parts you are suggesting, right? I realize this may be a dumb question, but I just want to confirm before I pull the trigger. Is there any reason I wouldn't just pay an additional $20 for the full ice maker assembly? Is it easier to replace it all?
    Yes, KitchenAid and Whirlpool are identical for parts.
    Yes, its actually better to pay the little more extra to get the complete ice maker assembly, so you don''t have to take the ice maker apart at all, just remove the old ice maker, and install the new ice maker, much easier.
    Apr 2009
    arizona
    Default trouble
    OK, I tested the inlet valve using the shortcut wire and it worked, I bought and installed a new icemaker and it still is not working. It does not fill up with water and do its thing. It is as though the little motor isn't working to send the signal to the inlet valve and so on...
    Now what do I do to get this solved, because buying ice sucks...
  1. Replies: 1
    Last Post: July 10th, 2014, 08:28 PM
  2. Replies: 1
    Last Post: October 6th, 2013, 06:13 PM
  3. Replies: 3
    Last Post: July 21st, 2013, 03:31 PM
  4. Ice maker water supply line leak
    By Lars in forum Sears Kenmore
    Last Post: December 16th, 2011, 07:56 PM
  5. Gas solenoid testing help
    By ricrivera in forum Sears Kenmore
    Last Post: February 5th, 2011, 10:34 AM
