Results 1 to 4 of 4
Thread: GE MONOGRAM Dishwasher Won't Drain
    Jan 2009
    atl
    Default GE MONOGRAM Dishwasher Won't Drain
    Model Number: ZBD6880K10SS
    Brand: GE
    Model Number is ZBD6880K10SS. Won't drain. Removed drain hose, removed disposal elbow, p trap, everything is very clean. Sink and disposal work fine. Removed the plastic screen device over the DW drain, removed all the standing water and some amount of crud, but nothing that appeared to be significant enough to prevent drainage. Can see all the way to the bottom of the sump, looks all clear.
    We are in GA, local codes don't require an air gap, and we don't have one. GE Answer Center was a woman reading the manual out loud to me, thanks for the help. I have not yet re-run the DW to see if it works, but again, I didn't remove any debris that was significant enough to cause the no-drain problem. Unit is 3 years old, lightly used family of two.
    Suggestions would be appreciated!
    Now when it trys to drain, do you hear the drain motor come on or is it just dead? No noise at all from the dishwasher?
    Your model has a separate drain pump motor, its #325 here: Parts for GE ZBD6880K10SS: Motor-Pump Mechanism Parts
    If that motor is just humming and not draining, then you either have something jammed/clogged in it, or your drain motor is bad.
    Here's the drain pump motor assembly for your model:
    GE WD26X10039 Pump Drain Asm - AppliancePartsPros.com
    Jan 2009
    atl
    Default Followup
    It is humming, not dead. How is the pump accessed?
    You have to take off your lower front access panel #759 here: Parts for GE ZBD6880K10SS: Escutcheon & Door Assembly Parts
    And you may need to remove your outer door panel#711, should just unscrew from the inside door liner.
    If you still can't get good access to it, you may need to pull your dishwasher out, which would require you to remove the water supply line and electrical and drain hose if they are not long enough to pull out with the dishwasher.
  1. Replies: 3
    Last Post: November 6th, 2014, 09:25 PM
  2. GE Monogram dishwasher not starting
    By woodygg in forum GE/Hotpoint
    Last Post: September 2nd, 2013, 01:16 PM
  3. GE Monogram Dishwasher Buttons Not Working
    By euric82 in forum GE/Hotpoint
    Last Post: November 17th, 2012, 01:32 PM
  4. FIXED: GE Monogram Dishwasher Buttons Not Working When Door is Open
    Last Post: September 28th, 2012, 07:15 AM
  5. GE Monogram drain plug issue
    By conviso in forum GE/Hotpoint
    Last Post: September 17th, 2006, 12:08 AM
