Results 1 to 6 of 6
Thread: Maytag noisy while agitating
    Jan 2009
    Kansas
    Default Maytag noisy while agitating
    When Maytag MAV208DAWW is agitating there is this loud clunking noise. It does it less with a lighter load, more with heavier load.
    Repairman said it was because the brake was bad, he could hold the tub and the noise did go away. Also, you could see the tub move just a small amount with the agitating.
    Now he wants $98 to fix and I don't mind if that is really the problem.
    Why I question the diagnosis is that if you open the lid during spinning, the tub stops quickly and is difficult but possible to turn the tub. Doesn't take two hands, but you can feel that it's being held.
    Is this a hard task to replace the brake????? I do pretty good on most things. Just changed the two front rotors, calibers on one side and pads on my daughter's van. By the same token if it had been my vechicle I might have taken it to get fixed, but I knew she couldn't afford it.
    How old is your washer? If you don't know, post your serial# and I can tell you.
    I remember a few years back there was a issue with the 3 transmission bolts not being tight enough from the factory and causing this, but thats been like more than 5 years ago, and haven't seen one since then do it.
    You would need a brake tool kit to take the brake off, its about $100 and for using it once in a lifetime probably doesn't justify buying it.
    You can see if someone at the repair shop can let you rent it, and see if those 3 bolts are loose.
    I remember one I did, that even tightening them didn't fix it, the transmission threads were stripped and I had to order a new transmission, which you have a 5 yr. part warranty on, if your washer is less then 5 yrs. old.
    Here is the brake tool:
    Brake/bearing/seal removal tool kit
    Jan 2009
    Kansas
    Thank you for the reply.
    Serial number is 27080613JR, purchased this in November 2006. Since the brake need replaced, I was surprised that the spin cycled stopped so quickly and the tub did have resistance when turning manually. Then on the other hand, I didn't ever try to spin the tub or lift the lid during the spin prior to today.
    Jerry
    Ok Jerry,
    Your still in the 5 yr. transmission warranty period.
    Jan 2009
    Kansas
    Very strange thing happen after months of noise my washer is not about 80% quieter. Notice above how I was testing how the brake worked just fine during the spin cycle. I did this several times and it always stopped quickly. Also, it was difficult to turn the tub, which means the brake was holding. I am guessing that must have seated the brake? I don't have a clue how the washing machine brake works, but if anything like the old drum and brake shoe on cars, I can see how forcing a stop during the spin may have helped. Maybe it won't last long, time will tell? BTW the repairman said I only had a year on my gearbox and looking at the manual that came with the washer, it appears to only be a year. Oh well maybe all will be AOK.
    Oh yes, I forgot they changed the warranty from 5 yrs. to just 1 yr. now.
  1. Noisy In Spin Maytag Washer
    By kjr232 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 23rd, 2008, 12:40 PM
  2. Noisy, hard starting maytag
    By Desert Toad in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 1st, 2008, 12:51 PM
  3. Maytag Performa PAVT244aww NOISY
    By murman92 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 15th, 2007, 11:47 AM
  4. Noisy Maytag while Draining
    By Pontihog in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2007, 12:34 AM
  5. Maytag dryer noisy and hot
    By KenR in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2005, 06:09 AM
