Results 1 to 4 of 4
Thread: Kenmore oven won't work after self-cleaning
    Feb 2009
    San Diego
    Unhappy Kenmore oven won't work after self-cleaning
    I have a Kenmore electric double oven, 790.47763400. After running the self-cleaning feature on both ovens, not at the same time, the bottom oven does not work. The top oven still works for both bake and broil. When setting the bottom oven to bake or broil, the display lights up, a few clicks are heard, but neither the baking or broiling elements heat up. The display shows no error messages and appears as it before self-cleaning.
    Lets first ohm the safety thermostat with an ohm meter, if you don't have an ohm meter you can jump the safety thermostat using an alligator clip or taking the wires off of it and using electrical tape to tape them together, just to see if the bottom oven comes on.
    The safety thermostat is located in the back of your oven, so you would need to pull it out from the wall, you may need someone to help you.
    Remember to turn the breaker off to your oven before touching any wires and before removing any panels.
    Then take off the back access panel and its #219 here: http://c.searspartsdirect.com/lis_pn...9047-00003.png
    Here's the safety thermostat for your model:
    Cycling Thermostat 318003606 Order now for same day shipping. 365 day return policy. RepairClinic.com
    If the safety thermostat is ok, then its likely your relay board.
    Here's the relay board for your model:
    Relay Board 316429800 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Feb 2009
    San Diego
    Default Jake
    Thank you for the info. I was wondering if it could be the oven sensor inside the oven on the back wall?
    Not likely, that just controls the temp. once the oven is on already, a bad oven sensor wouldn't make the oven not come on at all.
  1. Kenmore oven won't work somtimes
    By swebeaux in forum Sears Kenmore
    Last Post: December 8th, 2008, 01:40 PM
  2. Kenmore gas burners work, oven doesn't
    By steavis19 in forum Sears Kenmore
    Last Post: December 8th, 2008, 07:20 AM
  3. Kenmore self cleaning oven insert stuck
    By Bebonang in forum Sears Kenmore
    Last Post: January 15th, 2007, 11:31 AM
  4. kenmore elite dual fuel range oven doesn't work
    By dawn in forum Sears Kenmore
    Last Post: October 2nd, 2005, 11:25 PM
