Results 1 to 4 of 4
Thread: Whirlpool Front Load F22 Error Code
    Dec 2006
    DAUPHIN, MB
    Default Whirlpool Front Load F22 Error Code
    I Have A Whirlpool F/l Washer Model #wfw9200sqa1. There Is An Error Code That Comes Up F-22. Can't Seem To Find That Code In The Repair Clinic Error Codes List. Can Anyone Help? Thank You. Rizzo
    Oct 2004
    wfw9200sqa1
    I found WFW9200SQA10 WFW9200SQA11 WFW9200SQA12
    I found, a copy:
    F22
    DOOR LOCK ERROR
    A Door Lock Error occurs if the door cannot be locked. It will try
    to lock it six times before displaying the error code.
    Possible Causes/Procedure
    Door lock mechanism is broken or removed from door.
    Door switch/lock unit failure.
    1. Unplug washer or disconnect power.
    2. Check door switch/lock unit.
    3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
    http://www.applianceaid.com/
    Appliance Repair Aid
    Dec 2006
    DAUPHIN, MB
    Default Sorry Jeff..
    The Model Is Wfw9200sqa12. I Will Check What You Asked Me To And Let You Know How I Make Out. Thanks Again! Rizzo.
    Oct 2004
    Wfw9200sqa12
    Tech sheet for your model is located in the bottom of your washer.
  1. Maytag Front Load Washer Agitator
    By CryinCoyote in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 11th, 2009, 11:41 AM
  2. Frigidaire front load washer parts for sale
    By flybob in forum Buy, Sell or Trade
    Last Post: February 9th, 2008, 11:03 AM
  3. Front load Whirlpool 9200 extended warranty
    By kevinheap in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 10th, 2007, 06:15 PM
  4. Whirlpool Ultimate Care II leaking from the front
    By Johnnyr2 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 23rd, 2007, 09:41 PM
  5. Whirlpool Duet, Maytag Neptune, Frigidaire Front Load???
    By soundjunkie in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 7th, 2006, 06:22 PM
