Results 1 to 4 of 4
Thread: Jenn Air Mdl# W156W touch pad issues
    Jun 2009
    Auburn, CA
    Default Jenn Air Mdl# W156W touch pad issues
    I have a Jenn Air wall oven, model W156W with touch pad issues. The appliance does not display any fault code or beep but all of the control pads except the Probe pad are not responding. The Probe pad appears to work correctly as does the clock set controls and the clock itself. How can I confirm the touch pad-front panel assembly is bad and not the timer circuit board.
    This must be an older model, I can't locate a tech. data sheet for it online. But the tech. data sheet should be located in your control console behind the touchpad assembly.
    Make sure you turn your breaker off to your wall oven first before opening it up!
    But to me it sounds like a bad touchpad assembly.
    Here's the one for your model:
    Manufacturer part number Y04100037 is RepairClinic item number 1242473
    Y04100037
    We have a special program here, all parts you order from our links we post are returnable within 30 days for a FULL refund if they don't fix the problem.
    Jun 2009
    Auburn, CA
    Thanks for the response. This is an older unit, purchased from a builders supply warehouse in 95 but the code on the timer board indicates the unit was built in 91. The data sheet in the back of the unit does not have a detailed schematic or a test chart for the touch pad. Based on your counsel and everything I have done, I believe it's the touch pad assembly as well. The picture in your response looks correct......except my unit has a white face. I'm hoping these typically came in two colors and my unit isn't a one off.
    I much appreciate your service to this community
    Casey
    Thanks Casey,
    Unfortunately it only comes in black now. They have discontinued the white one for some reason.
  1. Jenn Air JCD2389GT- Freezer not cold enough & ice maker issues
    By UncommonDave in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 6th, 2009, 12:44 AM
  2. jes9750aab touch pad woes
    By pistofconsumr in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 6th, 2008, 05:31 PM
  3. Jenn Air Range- Probe Pad Error
    By cookswithgas in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 6th, 2007, 09:44 AM
  4. Jenn Air Wall Oven With Fault Code 1
    By AFH in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 3rd, 2006, 11:52 AM
  5. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 5th, 2006, 11:39 PM
