Results 1 to 6 of 6
Thread: How do I bypass lid switch on my washer?
    Oct 2005
    Maryland
    Default How do I bypass lid switch on my washer?
    Model Number: MAV7757AWW
    Brand: Maytag
    Hello,
    I have a Maytag ensignia washing machine that the lid switch is not functioning properly. If I manually depress the switch, the machine will work. However, for some reason, the lid itself is not able to close the connection.
    Can I just hardwire around this switch? There are five wires going into the switch. White, Black, Yellow, and 2 reds bundled together.
    How do I do it?
    thanks
    Mack
    Oct 2005
    Maryland
    I would appreciate any help you can give me. I need to do about 5 loads tonight before I leave for a month tomorrow.
    Mack
    Jan 2005
    Moorpark (via Motherwell, Scotland), California, USA
    The only way is to ohm check it with a multimeter.
    Check for continuity between the black (L1) wire and the red (SW) wire, and the white wire and the yellow wire with the lid open. In the closed position, check for continuity between the black wire and the yellow wire.
    Lid Switch Assembly 22003804
    Dec 2006
    Phoenix
    Quote Originally Posted by Mad Mac View Post
    I'll PM you re this.
    I am having a problem also wih the dor switch on my Maytag washer Model #: MAV7600AWW. I too would like to byass the door switch.
    Can you give me some info?
    Jul 2014
    I am having the same problem...I already purchased the the strike...that did not help...I am planning to purchase the lid lock assembly if this fix works....That is, I would like to bypass the switch temporarily to see if the washer than spins....In essence, would you know how to bypass the lid lock of this particular unit. I have looked on youtube...and onlly found instructions for lid locks with three wires...whit..grey and green....
    The videos say to jump the grey and white wire together....Ready to apply this fix I open my machine and voila....there are four wires...red..white..blue and yellow....Which wires would I have to jump...I really appreciate it...I bought this washer two years ago and already does not work....Would you be able to pm me some help . washer is Maytag
    MVWC300XW1...Centennial...
    Oct 2004
    This is a latch and lock, cannot bypass.
Size:  3.1 KB LINK> Lid latch assembly
    http://www.applianceaid.com/
    Appliance Repair Aid
  1. Lid Lock Broke of Maytag Washer - How do I bypass till I can get the part tomorrow?
    By Juliene in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 21st, 2013, 03:23 AM
  2. FIXED: New Washer Lid Switch Issue
    By tclotworthy in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 7th, 2012, 02:20 PM
  3. Washer will bypass Spin Cycle
    By teknicalissue in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 19th, 2011, 01:06 PM
  4. check switch bypass?
    By johnt in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 3rd, 2007, 12:16 AM
  5. Water Filter Bypass without a Bypass?
    By yuzow in forum Frigidaire/Electrolux
    Last Post: January 5th, 2006, 11:47 AM
