Results 1 to 8 of 8
Thread: [FIXED] Kenmore 70 Series 110.67732791
    Jun 2009
    University Place, Washington
    Default [FIXED] Kenmore 70 Series 110.67732791
    Hello,
    This problem relates to the thread that is now closed but just wanting to verify that our model is one that may have the same solution in regards to the bad control board.
    It will only run while holding the start button down. If you open the door and hold the door switch down and try starting, the drum barely turns.
    Appreciate any help you can give.
    Cheers,
    B
    Do you hear any kind of grinding sound when the drum barely turns?
    So if you let the start button go, everything stops?
    Jun 2009
    No grinding. The other thing I forgot to mention was recently it would make a loud squeaking noise, but would lessen considerably when you took the lint trap out.
    Yes, everything stops when you let go of the start button.
    Ok, on this model you don't have the electronic control board or the motor/heater relay's that you could swap.
    So it basically comes down to bad run windings on your motor.
    This dryer was made in 1997, so I'd give alot of thought before putting a new motor in it, when other parts are wearing as well.
    Here is the motor for your model:
    279827
    Here is a link for help changing it:
    http://www.applianceaid.com/wpmotor-change.html
    Jun 2009
    Thanks Jake,
    Well something to ponder. Luckily, I work at a hardware store where we have access to appliance parts, so with my discount it may lower the cost some. I'll let you know if we can salvage.
    BDG
    Ok, sounds good BDG, let us know what you decide.
    Jun 2009
    Well I'm happy to say the new motor is in and working like a champ. Plus, I found about $3 in change once I got it all apart. Thanks again for all your help Jake.
    BDG
    Excellent BDG, good job installing the new motor. Plus the extra $3 in change.
  1. [FIXED] kenmore 70 series dryer thumping noise
    By powellken in forum Sears Kenmore
    Last Post: June 13th, 2009, 11:55 PM
  2. Replies: 9
    Last Post: May 9th, 2008, 05:07 PM
  3. Kenmore 80 Series (110.92582100) Won't Fully Drain...
    By Sir_Brizz in forum Sears Kenmore
    Last Post: November 5th, 2006, 02:06 AM
  4. Kenmore 80 Series Model # 110 66822694
    By kingd in forum Sears Kenmore
    Last Post: June 9th, 2006, 01:07 AM
  5. Kenmore 80 Series washer fading clothes
    By kimberell in forum Sears Kenmore
    Last Post: August 11th, 2005, 10:10 PM
