Results 1 to 9 of 9
Thread: [FIXED] Kenmore Elite HE3T 110.42922200 Drain Pump
    Jan 2009
    Winchendon, MA
    Default [FIXED] Kenmore Elite HE3T 110.42922200 Drain Pump
    Hello:
    Our Kenmore Elite HE3T 110.42922200 has that "takes forever to drain before high speed spin" problem. It does eventually complete the cycle but research here seems to indicate that the drain pump is failing. The pump is also makes much more noise than before so I assume I need Part Number: AP3953640.
    Just looking to confirm and to ask if the Whirlpool Duet Manual covering models GHW9100L and GHW9200L is the correct reference to use.
    I might as well take care of this now before it fails completely.
    Thanks in advance,
    Skip
    Hi Skip,
    It sounds like the water pump is going bad.
    Here's the water pump for your model:
    Manufacturer's Number: 280187
    Yes, its the same repair manual.
    Here is the online repair manual for the Duet/Kenmore HE3T:
    http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
    Jan 2009
    Winchendon, MA
    Thanks! Part ordered. I appreciate the online manual, thank you.
    I'll check back when the job is completed.
    Thanks again,
    Skip
    Sounds good Skip.
    Jan 2009
    Winchendon, MA
    Default Fixed
    The new pump did the trick -- went right in.
    Thank you! You have saved me two service calls (one recently for the dishwasher and one now for the washer), I really appreciate it!
    Thanks again,
    Skip
    Jan 2009
    Winchendon, MA
    Default BTW, Do these units stack?
    I forgot to ask, is there a stack kit for the washer and dryer? I have them on the pedestals but I'm considering stacking the dryer on top of the washer, or is this not a good idea?
    Skip
    Glad the new pump fixed it Skip.
    I'm not sure if there's a stack kit available or not, Sears would know, if you go to you local Sears store they can tell you.
    If you have a good solid floor(cement floor always the best) then it should be fine.
    Jan 2009
    Winchendon, MA
    Thanks Jake.
    Skip
    Anytime Skip.
  1. Kenmore Elite HE3 drain problem
    By ninez in forum Sears Kenmore
    Last Post: February 6th, 2012, 12:37 PM
  2. Kenmore Elite 665.16933000 won't drain after washing
    By dbsimms63 in forum Sears Kenmore
    Last Post: June 6th, 2009, 06:34 AM
  3. Replacing inner drain hose on Duet He3T #110.42922200
    By leadfinder in forum Sears Kenmore
    Last Post: August 10th, 2007, 12:37 AM
  4. Kenmore HE3T 110.42922200 F02, Drain Pump?
    By nowhere in forum Sears Kenmore
    Last Post: February 11th, 2007, 11:42 AM
  5. Kenmore Elite He3t model 110.42932200 drain problem
    By Edwin in forum Sears Kenmore
    Last Post: July 6th, 2006, 10:50 AM
