Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Kenmore Model 665 Ultra Wash won't drain
    Aug 2009
    fayetteville, ar
    Default Kenmore Model 665 Ultra Wash won't drain
    Model Number: 665.15812990
    Greetings. And thank you very much in advance for any assistance with this issue.
    Our Kenmore 665 has been operating flawlessly for several years, but recently its ran into some problems with its ability to drain and/or operate. On the normal wash cycle, the base fills up at the beginning with water as normal, but then the wash cycle fails to initialize. The red light on the "cancel/drain" button lights up and the dishwasher quits. At that point, if I were to push the "drain" button, I hear a few clicking sounds as if a motor has seized up and nothing happens. So then the only way to drain the dishwasher at that point is to do it manually by removing the drain hose from underneith.
    Ive inspected the air gap and it seems to be free of any obstruction. Ive also inspected the check valve and as far as I know it seems to be in perfect working condition as well.
    Thank you very much with your assistance as any advice with this issue is greatly appreciated.
    You should have some numbers after the 665 in your model#, as they make 3 different style pumps for the Kenmore models. The model# tag is located inside the door on the side of the tub frame.
    Aug 2009
    fayetteville, ar
    Thank you for the reply.
    Model: 665.15812990 Serial: FJ3304954
    Stock: 15812
    On this model you don't have a separate drain pump, so if its not draining, then your motor has seized up or something is jammed/stuck in your upper or lower impeller.
    Here's the impeller kit for your model:
    Impeller and Seal Kit 675806 Order now for same day shipping. 365 day return policy. RepairClinic.com
    675806
    The hardest part is getting the impeller screw out.
    Jeff explains here how to do it: http://www.applianceaid.com/dishrepairhelp.html
    Here's the pump/motor assembly for your model:
    Pump and Motor Assembly W10428774 Order now for same day shipping. 365 day return policy. RepairClinic.com
    675800A
    Apr 2005
    Default Kenmore Ultra Wash 665 Not Draining
    Hi Jake,
    I'm having a similar issue with mine...
    Here's my dishwasher's info:
    Model 665 15812990
    Serial: FK2044122
    Stock No.: 15812
    It was making a very lound grinding noise a day or two ago, but then it stopped... but now, no drainage.
    Assuming that since the model number and stock number are the same, that's the same for me.
    So I would need the impeller kit and pump motor?
    Thanks for your help!
    Now what I find on these models 95% of the time when it won't drain properly is the check valve clogged.
    There should be just a black rubber flapper inside that check valve, push something through it, like a pen, it should go through. Also flush it with water from your sink.
    Here's the check valve for your model:
    Check Valve 675238 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video to access it:
    If the check valve is clear and not clogged, then check the drain impeller to see if its broken or cracked, its the gray one in the photo below.
    The impeller kit is a different part# for your model, but the video to access/change it is the same.
    Impeller and Seal Kit 8193524 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video to access/change it:
    Apr 2005
    Hi Jake, thanks for your great advice... I checked the check valve, looked to be OK... So I pulled the inside of the dishwasher apart, and sure enough the grey piece was chewed up where the little spring thingy is supposed to fit in. Also found a plastic milk cap, a hard straw, and a cap from a Kool-aid bottle. Ordering my new impeller kit now, and assuming that will take care of it. I'll post a picture of the grey piece if I can figure out how! In the meantime, thanks again... left a tip for ya in the donation tip jar.
    Apr 2005
    Default Impeller
    Here's what the old impeller looks like.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	9365   Click image for larger version.
ID:	9366   Click image for larger version.
    Yuppers, thats it woz.
    You should be back in business when you get the new impeller kit installed.
    May 2013
    Colorado
    Jake: hi I have a kenmore ultra wash dishwasher that won't drain the water is gross and stinks. I got everything out of the bottom and tried the cancel/drain button and it still didnt go down. i tryed that about 6 times. I was wondering if you can tell me what else I should do.
  1. 665.1765992 Kenmore Ultra Wash III won't drain + some questions
    By JStandiford21 in forum Sears Kenmore
    Last Post: April 27th, 2012, 05:43 PM
  2. Replies: 5
    Last Post: January 15th, 2012, 11:40 AM
  3. Kenmore Ultra wash 665.17685790 doesn't drain
    By mdoane in forum Sears Kenmore
    Last Post: August 17th, 2010, 08:32 PM
  4. Kenmore Ultra Wash 665 Fills but no wash or drain
    By hornist in forum Sears Kenmore
    Last Post: May 16th, 2010, 03:59 PM
  5. My new Kenmore Elite Ultra Wash won't drain properly
    By brimmer in forum Sears Kenmore
    Last Post: August 13th, 2006, 10:40 AM
