Results 1 to 2 of 2
Thread: Frigidaire front load washer beeping
    Dec 2008
    Florida
    Default Frigidaire front load washer beeping
    I have a Frigidaire front load washer.
    Model # LTF2140ES3
    Serial # XC62302363
    (Appears to have been mandufactured in May 2006).
    The other night it began to beep and one of the lights (Start light, I think) would light up. Machine would beep and light would light just once, every few minutes, and not at any regular interval.
    Unplugged it overnight and then plugged it back in.
    After a few minutes, all of the lights came on--like it used to do when i had set the cycle type, water temp, etc., and it was waiting for me to hit Start. But after a few minutes, all the lights went out and the machine would not respond at all. (For example, no beeps or lights when you turn the cycle type selector knob or water temp selector knob.)
    I have not tried to run a load since this started happening, as I am afraid of the machine starting but then stopping with my wet clothes locked inside.
    I have unplugged the machine again and plugged it back in, and the same thing as described above happens again.
    I have a matching Frigidaire dryer which I bought at the same time.
    About a year or so ago, it began to beep and stopped working.
    I had to replace the control panel on it.
    Any thoughts? Thanks in advance.
    Yes, sounds like your control board is malfunctioning.
    Here's the control board for your model, you can order:
    Manufacturer part number 137005000 is RepairClinic item number 1464889
    137005000
    Here's the repair manual for your model, it will explain how to access and change it:
    www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
  1. Frigidaire front load washer parts for sale
    By flybob in forum Buy, Sell or Trade
    Last Post: February 9th, 2008, 11:03 AM
  2. Belt falling off of Frigidaire Front Load Washer
    By cschlete in forum Frigidaire/Electrolux
    Last Post: November 26th, 2007, 06:45 PM
  3. Frigidaire ATF7000ES Front Load Washer E10 Error
    By nookerdude in forum Frigidaire/Electrolux
    Last Post: November 13th, 2006, 11:51 PM
  4. Frigidaire front load washer sounds sick
    By Seal in forum Frigidaire/Electrolux
    Last Post: October 24th, 2006, 09:18 PM
  5. Frigidaire Front Load Washer loud
    By sid58ney in forum Frigidaire/Electrolux
    Last Post: August 14th, 2006, 02:17 PM
