Results 1 to 6 of 6
Thread: frigidaire washer ddo error code
    Aug 2009
    Kingston
    Default frigidaire washer ddo error code
    Model Number: GLTF2070DS0
    Brand: Frigidaire
    model #gltf2070dso i found the magnet attached to the dispenser drawer and found the object under the top of machine that magnet "tells" that the door is closed held them together for 5 minutes machine ran well then stopped again with error code ddo now what
    It sounds like possibly your reed switch is bad.
    Is the magnet under the dispenser drawer secure? I've seen many just fall out and cause the ddo error code.
    Here's the reed switch assembly for your model:
    Manufacturer part number 134204300 is RepairClinic item number 1036404
    134204300
    Aug 2009
    Kingston
    Default reed switch
    thanks for your info with the reed switch i ended bypassing the switch and the washer worked fine until another problem arose with either the transmission or the motor i left info on that yesterday the 27th hope you get to investigate my problem soon thanks again
    I don't find any other posts you've made other than just in this thread.
    Aug 2009
    Kingston
    Default motor or transmission
    my washer will not agitate properly when it sounds like it should be moving i push on the large wheel(pulley) in back and it will agitate 9 or 10 ten motions then stops i do it many times to get wash to cycle through when it comes to final spin it takes a lot of coaxing to spin or i unload half the clothes to get it to spin it seems to be motor or transmission whats the difference or do i not have a transmission? thanks
    Ok, on this model you don't have a transmission, just the motor that turns the big pulley in the back of your drum.
    When its in the wash cycle does it move the inner basket one way, then reverses the other way?
    Is all the water draining out of it before the final spin? Because if the water pump is clogged and not draining properly it won't spin correctly.
    Take off the front bottom access panel and you will see a tech. data sheet that will tell you what to test as far as the motor is concerned.
    Let us know.
  1. [FIXED] Frigidaire GLTF2940ES1 washer repair question.
    By lharwerth in forum Frigidaire/Electrolux
    Last Post: September 1st, 2009, 09:03 PM
  2. FIXED: Frigidaire Washer GLTF2940ES0 Not Working
    By thatguyfromnj in forum Frigidaire/Electrolux
    Last Post: April 20th, 2008, 07:02 PM
  3. Frigidaire washer won't final spin
    By Cyberman in forum Frigidaire/Electrolux
    Last Post: October 27th, 2006, 10:07 PM
  4. Frigidaire stacked washer eating belts
    By Stephen Webb in forum Frigidaire/Electrolux
    Last Post: October 25th, 2006, 11:28 PM
  5. Frigidaire Washer stackable with Kenmore Dryer??
    By hawai in forum Frigidaire/Electrolux
    Last Post: November 22nd, 2005, 03:53 PM
