Results 1 to 5 of 5
Thread: Kenmore 110.27062602 washer
    Aug 2008
    louisiana
    Default Kenmore 110.27062602 washer
    this kenmore washer stops at the end of most wash cycles with 12 minutes left on the timer with a uL error code. If start is pressed again it may reoccur or sometimes it will finish the cycle. I only looked at it briefly, but I'm suspecting its the drain pump
    I wish I could help you on this, but I quit Sears just before the Oasis models came out, and haven't had the training or chance to work on any.
    Here's the tech. sheet for it:
    http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
    Hope that helps.
    Aug 2008
    louisiana
    Default what I've done
    ul means unbalanced load, got into diagnostics and pulled I believe a 51 which is the rps. Since this a known weak point, I replaced it along with the new harness kit. I'm sure the computer determines an unbalanced load using info from the rpg,but the problem persists. I'll post my progress. Any feedback would be appreciated Dave
    Aug 2008
    louisiana
    Default still not fixxed
    I've now replaced the motor control board. It worked fine for a couple times, I just got a call that uL is showing up again, kind of lost, but I'll post my progress, thanks
    David
    Hi David, did you ever resolve this issue?
  1. Replies: 16
    Last Post: January 22nd, 2012, 05:09 PM
  2. Kenmore Heavy Duty 70 Washer unbalanced - toast?
    By top_five in forum Sears Kenmore
    Last Post: January 9th, 2008, 12:30 PM
  3. Please diagnose my problem....Kenmore washer
    By Stinger44 in forum Sears Kenmore
    Last Post: December 7th, 2007, 07:57 PM
  4. Kenmore 70 series washer unbalanced
    By gerifalte in forum Sears Kenmore
    Last Post: November 1st, 2006, 02:31 PM
  5. Kenmore washer intermittent burning smell
    By mvmartin in forum Sears Kenmore
    Last Post: February 10th, 2006, 01:40 AM
