Results 1 to 4 of 4
Thread: Kenmore Dryer Taking a long time to dry
    May 2008
    MA
    Default Kenmore Dryer Taking a long time to dry
    I have a Kenmore dryer model 110.67042600 that is taking more than 3 hours to dry a normal load where it used to dry a load in about an hour. When I open the door during the cycle, it is hot in there so I think the heating element is working. I took apart the dryer and cleaned all the lint and actually found a lot of it. I also cleaned out the vent hose with a leaf blower and it still does not dry properly. I read another post where it could possibly the thermistor but I am unable to locate any parts for this model. Any help with fixing this issue would be greatly appreciated.
    Andy
    Hi Andy,
    The thermistor is #56 here:
    http://c.searspartsdirect.com/lis_pn...5022-00003.png
    It mounts on the blower housing.
    Now this model is a new one for me, I haven't worked on this model before, but it looks like it has a separate blower wheel rather than the blower wheel being mounted directly on the front of your motor.
    Long drying times usually indicate a vent restriction, I'd check your blower wheel and see if any lint is clogged in there as well.
    May 2008
    MA
    Thanks for the quick reply Jake,
    I did clean out a lot of lint around the blower wheel, however drying time is still about 2 hours for a load that is not even that big. Is there anything else I can check? Do you think the thermistor could be causing this issue? Another thing I noticed is that when starting the load on automatic, the timer starts at 40 minutes and counts down normally until it reaches 8 minutes. At that point it stays at 8 minutes for at least an hour. If I check the clothes during that time, that are still damp so I assume t is the moisture sensor keeping the dryer on because it senses they are not dry.
    Andy
    I wish I could answer that for you Andy, but I really don't know why its doing that.
    Another tech. or member may be able to answer that for you.
    Other than that, you may need to have Sears come out to see what the tech. finds out to fix it.
  1. Whirlpool Duet taking long time to dry
    By lowe408 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 29th, 2009, 06:13 PM
  2. Kenmore Dryer 417.94072301 No Heat
    By brimmyhop in forum Sears Kenmore
    Last Post: September 29th, 2008, 12:46 AM
  3. Kenmore Elite Gas Drier taking too long to Dry
    By mvetree in forum Sears Kenmore
    Last Post: May 9th, 2007, 01:07 PM
  4. Kenmore KUDS01IJ Noisy and taking long time
    By mbinder in forum Sears Kenmore
    Last Post: January 22nd, 2007, 11:15 AM
  5. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    By jnicosia in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 19th, 2005, 10:48 PM
