Results 1 to 4 of 4
Thread: whirlpool gold ice maker leaking
    Oct 2009
    spring, texas
    Default whirlpool gold ice maker leaking
    Hi Jake:
    You have probably already answered this a thousand times, but my ice maker on my WP Gold is leaking. It seems to be leaking from the front of the ice maker...dripping down the front of the unit. My model number is GD5YHAXNL02. One other thing the maker is doing is that one of cube slots consistently gets an ice cube stuck which ends up blocking the return of the "paddles" I think is what you call them. Then the unit won't make ice until you clear the stuck piece of ice. Appreciate your help.
    Tks, Paul
    Hi Paul,
    Yes, its your ice maker thats bad.
    Here's the ice maker for your model you can order:
    Complete icemaker assembly
    Manufacturer's Part#: 2198597
    Are you planing to replace it yourself?
    Oct 2009
    spring, texas
    Default installation instructions
    Jake:
    Hey, I ordered the icemaker. Will the instruction for removing the old one and installing the new one be included? If not, can you please advise installation procedures?
    Tks,Paul
    No Paul, it won't.
    Here's the instructions TO change the ice maker assembly:
    1. Remove the bucket from the door to get some room.
    2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
    3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
    4. Remove the screw in the right rear bottom side of the ice maker.
    5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
    6. On the left track the should be a tab toward the bottom which you need to push up.
    7. Push up tab and start working the ice maker towards you pulling it out of the track.
    8. Careful with the electrical harness in the back as you're pulling out.
    9. Disconnect the electrical plug by lifting the clip on the plug.
    10. Remove the side cover on the side module by pulling off.
    11. Remove the bottom shield by removing the 3 screws on the bottom.
    12. To install reverse the order as it came out.
  1. FIXED: Whirlpool ice maker water fill tube and cup freezing up
    By NDS in forum Whirlpool/Roper/Estate
    Last Post: July 22nd, 2013, 03:12 AM
  2. Ice Maker Troubles w/ my Whirlpool Gold Conquest GS6SHAXMS00
    By audreysmom in forum Whirlpool/Roper/Estate
    Last Post: May 31st, 2013, 07:01 PM
  3. Replies: 13
    Last Post: April 16th, 2011, 07:39 PM
  4. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
    Last Post: February 3rd, 2009, 10:52 AM
  5. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 12:56 AM
