Results 1 to 8 of 8
Thread: Ice and frost buildup in GE side-by-side
    Oct 2009
    Missouri
    Default Ice and frost buildup in GE side-by-side
    I don't imagine model number is needed here, but if it is, I can provide. We have a side-by-side model in our garage that does NOT have a water line hooked up; hasn't had one in over 5 years hooked up. For some reason, ice and frost build up at the opening at the bottom of the ice tray and into the opening on the door. Does anyone know what is causing this and how to stop it? Thanks.
    Jon
    Oct 2004
    A full model# is always needed!
    Where is my model#, I need a part, where should I look for my model number
    At the through the door dispensor? ( see how a model# would have helped )
    Where exactly is the ice/frost?
    http://www.applianceaid.com/
    Appliance Repair Aid
    Oct 2009
    Missouri
    Hi Jeff,
    The model # is GSS25JFMB WW. Thanks.
    Jon
    Oct 2004
    GSS25JFMBWW
    An electronic controlled refrigerator
    Oct 2009
    Missouri
    To try and be exact, the frost is building up in the opening of the ice maker bucket where the ice drops out of it into the opening on the inside of the freezer door. Thanks.
    Oct 2004
    Make sure the flapper door in the dispensor is closing/closing properly. Try a flash light to see if there is any opening/leaks allowing room air and freezer temp air to pass back and forth....
    #62.
    Oct 2009
    Missouri
    Jeff,
    Yes, you are correct, the flapper is not closing completely. I may need to take the door apart to find our why or cover the opening somehow (tape?) on the inside of the door. Any suggestions why it may not be closing? Thanks again.
    Jon
    Oct 2004
    A good reason for the frost and such.
    Some take apart helps...
    http://www.applianceaid.com/gethroughdoor.html
    Broken plastic piece, bad solenoid, wet/frozen insulation....
  1. Amana side by side Frost Problem
    By iamhere77 in forum Amana
    Last Post: August 21st, 2008, 11:58 AM
  2. Jen-Air side-by side not working - no ice build-up
    By hwg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 25th, 2007, 03:36 PM
  3. Frost Buildup in Freezer (model 106.63182302)
    By grundi in forum Sears Kenmore
    Last Post: May 27th, 2007, 12:20 PM
  4. GE Side by Side - Heavy frost on coils
    By mountainmommy in forum GE/Hotpoint
    Last Post: December 14th, 2006, 07:39 PM
  5. Coils inside freezer have ice and frost?
    By blandis in forum Refrigerators & Freezers
    Last Post: June 8th, 2005, 12:50 PM
