Results 1 to 10 of 12
Thread: Front loader 3 years old won't spin
    Nov 2007
    Victoria BC, Canada
    Default Front loader 3 years old won't spin
    Model Number: 970-C45192-30
    Okay, I have a 3 year old (bought new) Kenmore front loader washer model 970-C45192-30 that has stopped spinning.
    I have watched it on the spin cycle and the water pumps out, it tries to spin slowly a few times and stops after about one minute. Seems like an out of ballance thing, but we have tried adding or removing clothes and it does the same thing.
    When you watch it, the drum does not bounce around which would prove to me that there is no ballance problem and the shocks are good.
    I am going to pull the bottom hose off the pump to see if there is an issue there, I don't suspect there is.
    It aggitates the loads normal during the wash and rinse cycles.
    Can the machine store error codes? If so, how to I get them?
    Is there a sensor on the pump that tells the machine there is or isn't water left to allow the spin cycle to start?
    Damn thing, only 3 year old. Help me out it is Christmas and the wife doesn't enjoy hand wringing out clothes!!
    Nov 2007
    Victoria BC, Canada
    Follow up. I just ran a rinse/spin cycle with nothing in the machine and here is what iti is doing.
    -fills and aggitates as it should
    -13 minutes left starts to drain, does so at a normal rate
    -8 minutes left it stops the pump and starts to slowly spin each direction for about 5 seconds each way.
    -with 7 minutes left it stops and shuts off, cycle end chime starts.
    At a loss, so far. Opening up the machine now to see if there is something obvious.
    We did have a power outage during a windstorm a few weeks ago. I do know that the hydo crews tried to tun the power back on after a 2 hour outage and did so for about half a second when a transformer in the area blew and the power was out for another 2 hrs.
    Damage from a power surge? Every other electronic device in the house is fine.
    I don't have a parts diagram for Canadian models, but it sounds like either its the motor/motor controller.
    You should have a tech. data sheet in the bottom access panel that will tell you how to test the motor and motor controller.
    Nov 2007
    Victoria BC, Canada
    Okay, I found the tech sheet under the top lid. I am getting error 47 code.
    I took the door lock out and not sure where to test the ohms on it. I ran it through the diagnostic tests and everything works so I cleared the codes and running a rinse/drain cycle as I type this.
    I will see what it does and then check to see if any codes have reappeared.
    Nov 2007
    Victoria BC, Canada
    Nope, same deal. Drains and won't spin. I am going to check J2 on the board and see if the door lock is opening/closing the circut. If it is, it looks like it could be the board.
    DOH!
    Ok E47 means its the door latch/lock switch thats bad.
    I'm assuming your model is the exact same one as the Kenmore 417 models sold here in the states.
    Here's the Frigidaire/Kenmore 417 Service manual:
    3.0 cu.ft. Horizontal Axis Front-Load Washer (Good & Better Models): www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
    I'm assuming yours uses this one, they ship to Canada:
    Door Latch 131763202 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2007
    Victoria BC, Canada
    Thanks for all that info. I do suspect it is the door switch because I cannot get an indication of an open/closed circut when I push on the switch lever inside the mechanism.
    Strange thing is if I try to run it with the door open, it won't and flashes "dr". When I close the door it will start to run, just not spin.
    Yes, its the door latch/lock switch assembly, a new one will fix it.
    Nov 2007
    Victoria BC, Canada
    Okay, troubleshooting is done, it is the door latch/lock switch. I took the switch appart and carefully tripped the contact points to fool the computer, and low and behold it spins.
    That manual you linked me to did the trick. It explained how the door latch worked and gave me the courage to take mine appart.
    The door latch/lock switch I posted the link to above ships to Canada.
  1. Front Loader - No Agitate/Spin
    By ccozic in forum Sears Kenmore
    Last Post: November 23rd, 2014, 06:37 PM
  2. Kenmore Front Loader won't spin
    By MaureenA in forum Sears Kenmore
    Last Post: April 16th, 2014, 06:44 AM
  3. front loader wont spin
    By ondwater in forum Sears Kenmore
    Last Post: July 23rd, 2013, 05:05 PM
  4. Kenmore front loader 417 won't spin
    By GregoryB in forum Frigidaire/Electrolux
    Last Post: June 15th, 2010, 05:16 PM
  5. Front loader won't tumble or spin
    By fauxgenius in forum Frigidaire/Electrolux
    Last Post: October 30th, 2009, 10:41 AM
