Results 1 to 2 of 2
Thread: GE Monogram Wall Oven Problems
    Jan 2010
    Phoenix, AZ
    Default GE Monogram Wall Oven Problems
    I have a 6 year old GE Monogram wall oven #ZET837SB3SS with the following problems:
    1. Oven door wont completely close tight. Replace hinges?
    2. Convection bake function does not work. The fan comes on but no
    heat. All other functions work including Bake only.
    Any ideas?
    Yes, the oven door hinges would need to be replaced:
    Manufacturer part number WB10X10078 is RepairClinic item number 1550729
    I haven't worked on this model before, so I'm sure what's causing the convection bake not to work properly.
    I wasn't able to locate the repair manual for this either. You may need to have a GE tech. come out to repair this for you.
  1. Kitchenaid KEBI276DBL2 wall oven problems
    By spectorequipment in forum KitchenAid
    Last Post: March 9th, 2012, 03:53 AM
  2. Replies: 5
    Last Post: March 16th, 2011, 01:19 PM
  3. Replies: 7
    Last Post: August 4th, 2009, 04:48 PM
  4. Frigidaire Single Wall Oven Model# FEB30S7DCB, went blank
    By msarbpd in forum Frigidaire/Tappan/Electrolux
    Last Post: November 28th, 2007, 01:34 PM
  5. Jenn-air wall oven doesn't close & temperature is off
    By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 2nd, 2007, 11:14 AM
