Results 1 to 4 of 4
Thread: [FIXED] Super Capacity 465 model SF379LEKB Oven Issue
    Jan 2010
    Chicago
    Default [FIXED] Super Capacity 465 model SF379LEKB Oven Issue
    Model Number: SF379LEKB
    We have a Super Capacity 465 model SF379LEKB, initially, when the oven is cold it ignites and heats to the desired temp. Should we want to change the temp in any direction (increase / decrease) the oven shuts down. Additionally, after about 60 to 90 minutes of baking at a constant temp the oven shuts down. We do hear the igniter "click" for a few seconds but the oven does not relight. Only after the oven cools enough and the display indicates the "pre" condition (pre-heating) will the oven re-light.
    Lastly in October '09 the range was serviced by an independent appliance repair technician. The problem at the time was E1-F5 codes with no oven functions. These code appeared after we tried to use the self clean feature. The tech replaced the Cln Ctrl part.
    Here's another member with a similar issue and the new bake burner igniter fixed his:
    http://www.applianceblog.com/mainfor...nsisently.html
    Read page 2 of that thread.
    Its Possibly a bad bake burner igniter.
    Here the troubleshooting flow chart:
    www.applianceblog.com/manuals/DSI_manual.pdf
    Here's the bake burner igniter kit for your model:
    Part#8190618
    Jan 2010
    Chicago
    Default Problem Resolved
    Just wanted to follow-up and say thanks. Per your reply I replaced the overn burner / igniter. Replacing the part was easy and went with-out a hitch. I will say followed the trouble shooting process. However, whenever I tested the electrical connections the oven would not act up. After the oven multiple times with nothing to prove I just ordered the part.
    Thanks again for your help.
    Excellent, good job.
  1. FIXED: Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: November 11th, 2013, 08:31 AM
  2. [FIXED] E2 F1 code on Whirlpool 465 Super Capacity
    By HaMHanks in forum Whirlpool/Roper
    Last Post: June 28th, 2011, 07:40 AM
  3. Whirlpool super C 465 oven won't light
    By Northern Piper in forum Whirlpool/Roper
    Last Post: August 23rd, 2009, 12:29 PM
  4. Whirlpool 465 Super Capacity Oven Problem
    By patrickball in forum Whirlpool/Roper
    Last Post: November 6th, 2008, 07:25 PM
  5. super capacity 465 problem
    By CJBrad in forum Whirlpool/Roper
    Last Post: April 1st, 2008, 12:56 PM
