Results 1 to 8 of 8
Thread: [FIXED] Kenmore Dryer 110.96573200
    Jan 2008
    Huntsville, Alabama
    Default [FIXED] Kenmore Dryer 110.96573200
    Model Number: 110.96573200
    Well, I repair (with your awsome help) my washer then my dryer quits with the heat. Last week I noted a bunch of lint in the exit vent outside. But already, the internal temp of the dryer seemed weak at best. Today, no heat at all. 110.96573200 is the model number. These machines just need to last 6 more months. So what can I do to fix this? Is it worth it?
    Mike
    Hi Mike,
    For the heating problem, you would need to pull your dryer out from the wall, then take off your back access panel and ohm the thermal cut-off#1 and the heater assembly#4 for continuity
    Pic courtesy of www.applianceaid.com
    Make sure your dryer is unplugged first before testing! AND take the wires off both parts first before doing the ohm test for continuity.
    Radio Shack sells cheap volt/ohm meters if you don't have one.
    Here's the thermal cut-off for your model in case you need to order it:
    Manufacturer's Number: 279769
    Here's the heating element for your model in case you need to order it:
    Manufacturer's Part#4391960
    Jan 2008
    Huntsville, Alabama
    So, if I get a tone from the meter, the part(s) are shorted and thus bad?
    Mike
    Jan 2008
    Huntsville, Alabama
    OK, for what it is worth, the items #1 and #3 beeped on the continuity test. The heater element had no tone.
    Mike
    Jan 2008
    Huntsville, Alabama
    The element is burned out. I got it out. I am going to order both parts as a precaution. OK with you?
    Mike
    Yes Mike, thats fine.
    Jan 2008
    Huntsville, Alabama
    Dryer is working. Thank you!
    Excellent Mike, good job.
  1. Replies: 5
    Last Post: October 9th, 2009, 10:14 PM
  2. Kenmore Dryer 417.94072301 No Heat
    By brimmyhop in forum Sears Kenmore
    Last Post: September 29th, 2008, 12:46 AM
  3. Kenmore electric dryer does not heat.
    By fiabeg in forum Sears Kenmore
    Last Post: June 3rd, 2008, 10:22 PM
  4. Kenmore 70 series gas Dryer not heating right
    By pflowers in forum Sears Kenmore
    Last Post: February 12th, 2007, 09:14 PM
  5. Kenmore 90 Series Gas Dryer Problem
    By HomeRepairGreenhorn in forum Sears Kenmore
    Last Post: March 15th, 2005, 03:02 PM
