Results 1 to 8 of 8
Thread: WHIRLPOOL ACCUBAKE - Bake element not heating up
    Feb 2010
    Houston, Texas
    Question WHIRLPOOL ACCUBAKE - Bake element not heating up
    Model Number: RBS245PDB12
    I have an Accubake model# RBS245PDB12 electric built in wall oven. The broil element glows red, but the bake element only gets warm to touch it will not get to the set temperature. Do you know what it could be?
    Its either the bake element has gone bad, or the control board is bad.
    Manufacturer's Number: 8186024
    8186024
    You can ohm the bake element with an ohm meter, normal ohms would be anywhere between 11-50 ohms. Make sure your breaker is off to your oven first.
    You may be able to pull the bake element with the wires attached out enough from the inside of your oven, without pulling your complete oven of the wall. Then you just disconnect 1 wire from the bake element and do the ohm test.
    Here's the bake element for your model you can order if yours is bad:
    Manufacturer part number 9760766 is RepairClinic item number 1191063
    Feb 2010
    Houston, Texas
    I ohmed the baking element and it read 32.5 ohms. What else do you think it could be?
    Thanks, Jason
    Jason,
    Then it has to be the control board.
    You said the bake element would just get warm? it wasn't cold or room temperature?
    Feb 2010
    Houston, Texas
    That is correct, the bake element would only get warm; it would never glow red. Also, there is a heat light on the display that you can see momentarily when you press start, but it would never come on and/or stay on. Like I stated earlier, the broiler element will get red hot, but the bake element only gets warm to touch not even enough to melt butter. What do ya' think? Control Board?
    Jason
    Yes Jason,
    The new control board will fix it for you.
    Do you know how to access the control board?
    Feb 2010
    Houston, Texas
    Thanks for the information and the link to the new control board. I do know how to access the control board, but I cannot remember if it was just plug and play. I will let you know if this fixes the problem.
    Thanks, Jason
    To access inside your control panel open your oven door then take off the side trim#2 here on each side:
    I believe it just has one screw on each side holding in the trim, then once the trim is off you will see 2 screws on each side of the bottom of your control panel.
    Make sure you turn the breaker off to your oven first.
  1. Whirlpool dryer electric heating element won't stay lit
    By pmcmurtry in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 3rd, 2009, 06:24 PM
  2. FIXED: Replacing heating element - Whirlpool LEN2000PW0
    By jasa878 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 1st, 2008, 11:30 PM
  3. Jenn-Air SVD48600B Bake Heating Element NOT working
    By jfriedrich1961 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 1st, 2008, 12:41 PM
  4. [FIXED] bake element blew, now no heating
    By jhanna in forum Frigidaire/Tappan/Electrolux
    Last Post: December 27th, 2007, 10:51 AM
  5. kenmore 790.95420302 Bake element won't work
    By Raidermania in forum Sears Kenmore
    Last Post: August 25th, 2007, 01:14 AM
Tags for this Thread
