Results 1 to 6 of 6
Thread: Ice Maker water level adjustment
    Feb 2010
    Spring, TX
    Default Ice Maker water level adjustment
    Model Number: n/a
    I just replaced the icemaker in my Kenmore Refrigerator with the WR30X10093 Kit that fits many other models of refrigerators also. The water slightly overfills the ice tray and freezes the cubes together in the dump tray. Is there an adjustment to correct the amount of water to fill the tray or how di I adjust the WR30X10093 ice maker to prevent this?
    May 2010
    kansas city, mo
    Exclamation ge icemaker wr30x10093 adjustment ice cube size - manual
    There is a way to adjust the ice cube size for this model !
    On the top front of the unit, remove the small plastic screw cover (center-right). Then remove the phillips screw that holds the cover in-place. Then remove the icemaker plastic cover.
    On the right side is a spring-tensioned screw. Look close you will see +/-. Then look closer for the arrows that are raised into the white plastic.
    To INCREASE the amount of water (increasing the size of the ice cube), turn this adjusting screw COUNTERCLOCKWISE.
    To DECREASE the amount of water (decreasing the size of the ice cube), turn this adjusting screw CLOCKWISE.
    Jun 2010
    Montana
    Default Thank you, thank you!
    I've been having trouble with my icemaker harvesting cleanly, as all the cubes are frozen together as a chunk when it harvests. Nearly every time it hangs up in the fingers of the harvester. I've adjusted the water screw to reduce the run-time on the valve, and now we'll see. I'm sure this will fix the problem.
    Just following up, did this fix it?
    Jun 2010
    Montana
    It did, and it is still working fine, and I made the adjustment 6 months ago. Thanks for following up.
    Excellent, glad to hear that.
    Thanks for coming back to update us.
  1. FIXED: Whirlpool ice maker water fill tube and cup freezing up
    By NDS in forum Whirlpool/Roper/Estate
    Last Post: July 22nd, 2013, 03:12 AM
  2. Testing ice maker water supply at the solenoid
    By jptl in forum Sears Kenmore
    Last Post: April 21st, 2013, 08:29 PM
  3. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
    Last Post: February 3rd, 2009, 10:52 AM
  4. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
    Last Post: February 2nd, 2008, 05:05 PM
  5. Replies: 9
    Last Post: May 16th, 2007, 01:45 PM
