Results 1 to 2 of 2
Thread: low cold water flow on clothes washer
    Jul 2007
    Tennessee
    Default low cold water flow on clothes washer
    Model Number: LSQ9659PW4
    Water flow rate is quite slow. Use only cold water on wash and rinse, so removed and cleaned the faucet to hose inlet screen. Flow is a little better but still much less than when new. Water pressure is good. Removed the hose from the washer connection to clean perhaps a filter in the inlet connection on the washer.
    See what appears to be a sintered metal filter (or a filer clogged with sand and hardened). Looked for information or a diagram to determine if this inlet has a removable filter or just what is inside the inlet, but cannot find. Any info on what this is?
    Oct 2004
    New fill valve time.
    Water Inlet Valve - LSQ9659PW4
    http://www.applianceaid.com/
    Appliance Repair Aid
  1. Duet washer problem - cold water valve broken?
    By AlanM in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 21st, 2009, 01:02 PM
  2. Amana side-by-side filtered water flow issue
    By Steel_Cranium in forum Amana
    Last Post: April 21st, 2006, 04:19 PM
  3. Kenmore Elite not despencing cold water
    By marco97 in forum Sears Kenmore
    Last Post: August 29th, 2005, 11:40 PM
  4. Kenmore 80 series hot water flow adjustment
    By jspring in forum Sears Kenmore
    Last Post: July 25th, 2005, 08:57 AM
  5. Model 70 Kenmore cold water flows in at atrickle
    By Bruiser in forum Sears Kenmore
    Last Post: July 23rd, 2005, 06:19 PM
