Results 1 to 4 of 4
Thread: [FIXED] Maytag Neptune mde5500ayw baflle repair
    Feb 2010
    usa
    Default [FIXED] Maytag Neptune mde5500ayw baflle repair
    Model Number: mde5500ayw
    Brand: Maytag
    My Maytag Neptune electric dryer has a baffle coming loose. I'd like to know what size of screws I need in case they are lost and secondly how difficult to correct this problem. Any diagrams or step by step procedures of disassembly would be ideal. Thank you for your assistance.
    Here's the repair manual for your model:
    www.applianceblog.com/manuals/16023110.pdf
    Read page 5-1 to remove the front panel and 5-2 for the top. Then read 6-4 for the baffles.
    I'm not sure what size screw it is for the baffles, you can remove another screw from the baffle and take it to your local hardware store or appliance parts store in your area and they can match it up.
    Feb 2010
    usa
    Success!
    A bit of a time saver for all with this problem. Simply remove the front panel and you will have access to the bottom the tumbler. Line up the baffles, start the 5/16" bolts by hand and tight up with a socket wrench. Reverse the process and you finished.
    A pointer, now is a good time to vacuum out the bottom of the dryer, but do so carefully.
    Thank you again for your assistance Jake!
    Excellent, good job.
  1. Maytag Neptune Repair Manual
    By Jake in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 27th, 2016, 09:15 AM
  2. Maytag Neptune...should I buy it?
    By Klute in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2010, 07:23 PM
  3. Maytag Neptune 8700 repair issues & Maytag Rant.
    By jazzman_q in forum Maytag/Jenn-Air Reviews
    Last Post: May 19th, 2009, 11:40 AM
  4. FIXED: Maytag MAH3000AWW, ocassionally won't drain/spin
    By docmag in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 6th, 2009, 11:44 AM
  5. Maytag Neptune - No spin cycle
    By fox_1028 in forum Maytag/Jenn-Air Reviews
    Last Post: May 24th, 2006, 11:15 AM
