Results 1 to 9 of 9
Thread: kenmore electric dryer stops before cycle is complete
    Nov 2005
    crowley, la.
    Default kenmore electric dryer stops before cycle is complete
    My Kenmore 90 series electric dryer will start but will stop before cycle is completed. If you try and start it again the buzzer will buzz but will not start the dryer. If I wait 15 minutes are so it will start up again but will stop before cycle is completed. Also, during the cycle after 10 minutes or so there is burnt smell. Could you please give me some advice as to where to start my troubleshooting.
    Oct 2005
    Wichita Falls, Texas USA
    Model number would help here, tag is on the dryer after you open the door....sounds like you have a motor overheating and cutting off on the overload. Might be a bad motor or something causing it to overheat, like the blower wheel housing jammed full of stuff.....
    Nov 2005
    crowley, la.
    Quote Originally Posted by Pegi at Sams
    Ok the model # is 6690269 . Could you give me some more info. I will open the panel and look around to see if I see some obvious obstructions.
    Oct 2005
    Model number not coming up, need 3 numbers then a . then the other 7-8 numbers please...
    Nov 2005
    crowley, la.
    Red face
    Ok now I think I am on the same page...the model # is 110.66902691. Thanks again...
    Oct 2005
    The dreaded DOTT dryer, need to see what all might be in your vent housing after you remove the front panel, if your vent to the outside is blocked this will be clogged with junk...
    Nov 2005
    crowley, la.
    Ok, I am going to open her up and see what I can find. The dryer has been running fine now for 30 minutes on the timed cycle.Go figure......
    Nov 2005
    crowley, la.
    Quote Originally Posted by ragincajundad
    Ok, I opened the lower front panel and found mounds of lint below the dryer. Thought maybe the problem was the lint and it motor was getting hot. Now that is all cleaned out the dryer will not come on. You can hold the buzzer but the dryer does not start only the buzzer works. Maybe the motor just gave out on the last cycle?
    Oct 2005
    Could be , all of the stuff clogging up the motor and air flow probably killed the motor, you will need to fix your dryer vent to the outside to keep this from happening again ...
  1. Kenmore series 70 dryer stop before cycle is complete
    By tsg13nm in forum Sears Kenmore
    Last Post: March 7th, 2007, 11:31 AM
  2. Kenmore Electric dryer series 90 shuts off
    By tomkat in forum Sears Kenmore
    Last Post: September 30th, 2006, 08:52 AM
  3. Kenmore dryer: how long should heat cycle?
    By ffspiel in forum Sears Kenmore
    Last Post: April 8th, 2006, 11:16 AM
  4. Kenmore electric dryer stops while running
    By dmc0215 in forum Sears Kenmore
    Last Post: January 17th, 2006, 07:45 AM
  5. Replies: 3
    Last Post: December 10th, 2005, 06:07 PM
