Results 1 to 10 of 10
Thread: [FIXED] F10 error code on new Kenmore range
    Mar 2010
    Japan
    Unhappy [FIXED] F10 error code on new Kenmore range
    Model Number: 790.36933900
    Bought a new kenmore slide in gas range about a year ago and took it with me to Japan. I am just now getting a new home finished and ready to use it and I take it out of the box, plug it in, and I got F-10 error code. I won't have gas hooked up for another week or 2, but should I worry about this? Is hooking up the gas going to change anything? This thing is brand never been used... Can't call sears cause all they got is an 800 number that doesn't work from Japan. Any ideas?
    F10
    Runaway Temperature.
    1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
    2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
    3. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
    I'd check and unplug your wire connectors to your EOC then plug them back in, then if that fixes it, may be a loose connection when it was shipped. Make you unplug your range first before you do this.
    Another member had this issue and resetting the wire connectors seem to fix it:
    http://www.applianceblog.com/mainfor...f10-error.html
    If it doesn't, then its your EOC thats bad.
    What voltage supply does Japan use? 120 volts like here in the States?
    Mar 2010
    Japan
    Thanks, I'll try messing with the connections and see if that helps. The Voltage here is a little different. I was wondering if that could cause any trouble. I have alot of things here from the states and never had a problem before. My computer, toaster, hairdryer, you name it, all came from the states for 120 volts but they work fine here. The voltage here is 100. If I actually measure it at the wall, its usually about 105-106 volts. If the EOC is bad, what does it cost for my model?
    Thats a good question, I'm not sure if your range would not fucntion properly on just 100 volts in Japan.
    I'll need to get with you tomorrow on the EOC cost and part# when the Sears site is back up.
    Mar 2010
    Japan
    Jake, I got myself a Voltage converter to see if that could be a problem and the same condition persists. What happens when I plug it in is at first the clock is blinking for a few seconds, then I get and F13 error for a few seconds and then it changes to F10 and it stays that way.... If you think this is the EOC, do you have a part # and price? Thanks...
    I really don't know if its the EOC or not, but its likely it is.
    Here's the EOC for your model you can order:
    p/n 318296817
    Mar 2010
    Japan
    Default Its Fixed.
    Thanks for your help Jake. The new EOC fixed the problem. Who would have thought a new unused oven would have a bad EOC, but then again, that oven had a long trip to Japan and maybe it got shaken up along the way. Thanks again.
    Excellent Bobino, good job.
    Apr 2010
    denver
    im about to take a look at a electric stove with a f10 error code , but its a 30 inch freestanding model, how many ohms am i looking for the the sensor probe itself? more than likely ill be looking at the eoc though
    1100 ohms at room temperature.
  1. [FIXED] Range 790.9641 F10 Error
    By daryl5056 in forum Sears Kenmore
    Last Post: January 25th, 2009, 12:33 PM
  2. Kenmore over not working, but range is.
    By Team Irish in forum Sears Kenmore
    Last Post: November 14th, 2008, 11:40 AM
  3. Kenmore slidein range installation problem
    By thulb in forum Sears Kenmore
    Last Post: November 21st, 2007, 12:41 PM
  4. Kenmore Range F10 code... help?
    By Derek in forum Sears Kenmore
    Last Post: June 10th, 2007, 12:14 PM
  5. Slow Preheat with Kenmore Electric Range
    By bigredrocket in forum Sears Kenmore
    Last Post: January 22nd, 2006, 04:18 PM
