Results 1 to 4 of 4
Thread: Samsung Thermistor error?
    Sep 2009
    Toronto
    Default Samsung Thermistor error?
    Model Number: dv4015j
    Brand: other
    I have a Samsung dv4015j dryer (part of the Big Wash set). When I start it, it works for less than a minute, then gives an E3 error. Belt was replaced previously. I phoned Samsung in the USA and was told it could be three things:
    1 - overload (too much laundry)
    2 - vent blocked
    3 - thermistor error
    #1 and #2 have been ruled out so it is #3. The operating manual that I have gives no schematic. I'll looking to repair it myself. Any ideas? Samsung said that I could look for open source manuals online but I have not found anything. Anyone know if this is an easy repair?
    I was told by someone at another site that:"The thermistor is located down at the front on the blower housing. 2 similar looking plastic pieces with 2 wires coming from it. The one on the left is the thermistor. Very very inexpensive to replace."
    Not sure where the blower housing is and what a thermistor looks like. Is it where the heating coils are?
    The thermistor should be mounted on the blower wheel housing.
    I couldn't locate the repair manual for your model exactly, but I did locate one here thats close to your model.
    On page 5-4 here:
    https://secured.whirlpool.com/Servic...tier_Dryer.pdf
    Sep 2009
    Toronto
    Thank you. I will have to try that when I am over at my parent's place. I guess I should measure the resistance to see if the thermistor is actually out (blown or shorted??)
    Unplug your dryer first!
    To test the thermistor you use a ohm meter and go by this chart:
    Here's the thermistor chart, it works on ambient temperature:
