Results 1 to 7 of 7
Thread: Stackable washer won't spin
    May 2010
    Atlanta, GA
    Default Stackable washer won't spin
    Model Number: 417.93802200
    Hello all...
    I have a Kenmore stackable that will go through all the cycles, but will not drain or spin. Any thoughts or suggestions?
    Thanks in advance!
    Adam
    Hi Adam,
    Does it make any sound when it goes into drain spin?
    If not, then It sounds like your lid/lock switch is bad.
    From www.applianceaid.com
    remove these screws and pull down on the front panel to remove it.
    To see if its bad:
    Just jump the 2 wires together that connects to your lid switch. Turn the power off first, then turn it on and try it.
    Here's the lid/lock switch for your model you can order:
    Manufacturer's Number: 134101800
    #50 here is your lid/lock switch:
    http://c.searspartsdirect.com/lis_pn...3522-00004.png
    May 2010
    Atlanta, GA
    Thanks Jake. It does not make any sound once it gets to the spin cycle, nor does the timer advance past that point. Also it will not lock the washer door. Does that change anything? I really appreciate your help!
    Adam
    May 2010
    Atlanta, GA
    My wife reminded me that the switch works in the aspect that it stops the aggitation when the door is opened. If there were a problem with the locking mechanism, would we still have the same problem?
    Yes, possibly.
    May 2010
    Atlanta, GA
    Thanks, Jake. I appreciate your service and advice!!!
    Adam
    The only way to tell for sure is to jump it like I said, if after that it doesn't drain/spin, then its likely the timer.
  1. FIXED: Kenmore washer won't spin out all water from clothes model # 110.15842400
    By Lewis-the-dog in forum Sears Kenmore
    Last Post: January 22nd, 2012, 05:09 PM
  2. Problem with spin cycle on Whirlpool DD washer
    By phil_v in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 22nd, 2009, 11:13 PM
  3. Admiral washer will not spin (LNC6762B71) - correct model #
    By ekoncepts in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 15th, 2009, 12:27 AM
  4. Matag Neptune Stackable washer wonít fill, lock, or spin
    By queencie in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 4th, 2008, 12:41 PM
  5. Help! Washer shaking during spin cycle
    By jasboods in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 2nd, 2007, 12:41 AM
