Results 1 to 10 of 11
Thread: [FIXED] My Kenmore He2 Plus
    May 2010
    Cushing, Oklahoma
    Default [FIXED] My Kenmore He2 Plus
    Model Number: 110.47511701
    We have a Kenmore He2 Plus Washer When you push the start button It turns off what do i need to do. Please Help
    I found another member that had this issue as well and the user interface fixed it: FIXED Kenmore HE2 plus wont start cycles
    Here's the user interface for your model you can order:
    User Control and Display Board 8574969 Order now for same day shipping. 365 day return policy. RepairClinic.com
    May 2010
    Cushing, Oklahoma
    Default Still shuts off
    I ordered the part from the link got it today. I installed it and it powers on and when you push start it shuts off just like the old one. I am way lost any help would be appreciated.
    Thanks Bruce
    Ok Bruce,
    Here's the repair manual for the Kenmore HE2/Whirlpool Duet Sport:
    https://secured.whirlpool.com/Servic...LE/8178558.pdf
    On page 6-11 it has a troubleshooting chart Read what it says in box 2 on the left side where it says WON'T START CYCLE.
    May 2010
    Cushing, Oklahoma
    Default Ran diagnostic
    Thanks for the link for the manual I ran some diagnostic on my machine and got an f24 code which I think is to do with the temp sensor. It went on to clean after that finished I tried to start it normal mode with same result. So if I am thinking right I need at least a temp sensor and maybe a heating element. If you think I am right do you have a sensor and maybe an element I would like to price them seperate. Any thoughts would be helpful.
    Still unsure thanks Bruce
    Thats very odd, it seems very unlikely a bad temp. sensor would cause the washer not to start a cycle at all.
    I'm kinda stumped on this issue. You may need to call out Sears to see whats going on.
    Have you checked your door switch button, that would make it not start a cycle.
    Some members have report it being broke off, but that was mostly on the HE3 models.
    May 2010
    Cushing, Oklahoma
    Default Fixed the problem
    I opened up the back because the repairman was going to come monday when I looked at the temp sensor there was a wire off. I fixed the wire and now it works. Thanks for the help still don't understand why the wire off shuts down the washer won't let it start
    WOW, thats a shook to me too, never seen that happen before.
    Good job finding that.
    Oct 2012
    Montana
    Jake, thank you so much for lookig into this issue. I had the exact same thing with my machine!!! Located the temp wire...
    yep unplugged. Ya think Kenmore would have a safety clip on this connector or??
    You are the man for gettin to the bottom of this issue.
    PS: after your tip I looked around from the front of the machine (after removing the front access panel) fumbled around
    and was able to re-connect without taking the rear panel off!
    Hey buddy THX again!!!
    Burnem55
    Oct 2012
    Montana
    Thx for the tip!!! It worked for me too!!
    Good job on tracking it down. I was able to re-connect from the front access panel after reading your
    research on the problem.....saved me a service call from>>>ya sears!! You are AWESOME bro!
  1. [FIXED] Fixed Kenmore series 90 electric dryer
    By Blackie in forum Sears Kenmore
    Last Post: February 16th, 2010, 12:55 AM
  2. Replies: 1
    Last Post: December 28th, 2008, 07:04 PM
