Results 1 to 2 of 2
Thread: Samsung dryer t0 error
    May 2010
    Denton, TX
    Default Samsung dryer t0 error
    Model Number: DV316LES
    Brand: other
    My dryer runs for a bit then gives a t0 error (looks like a lower case t or E without the top bar) and a few beeps and then shuts off. I have to power it off and then power back on and then it will run for a bit again.
    I spoke with a Samsung support person and they said the t0 error meant "thermistor open". I opened up the dryer and took out the thermistor and checked it with my multimeter. It doesn't seem to be bad as the resistance is going up when I cool it and down when I heat it.
    I cleaned everything thoroughly and re-assembled and I'm still getting the error. What next?
    Sep 2012
    florida
    Hello,
    I'm having the same error code and symptoms. Any ideas?
    If you subscribed to this post KRavEN, what was the problem?
    Thank you
  1. Error Codes for Frig LEQ1442ES0 stack dryer not in Tech Data Sheet
    By der Lump in forum Frigidaire/Electrolux
    Last Post: June 5th, 2010, 01:33 AM
  2. Samsung Thermistor error?
    By jdsr in forum Dryers
    Last Post: April 22nd, 2010, 09:18 PM
  3. Samsung B1113J Washer - E1 Error?
    By jdsr in forum Washers
    Last Post: April 21st, 2010, 10:57 PM
  4. Samsung dv4015j dryer - E3 error
    Last Post: September 16th, 2009, 05:16 PM
