Results 1 to 9 of 9
Thread: Dryer stops after a few minutes with heat on - will run continuously with heat off
    May 2010
    Wa
    Default Dryer stops after a few minutes with heat on - will run continuously with heat off
    Model Number: 110.63942101
    This just started today. We set the dryer for a 60 minute run with heat on medium. After three minutes it stops. During those three minutes, it put heat out. If I start it up again, it will run a few minutes and then stop. If I change the heat level to air only, it will run continuously and not stop.
    The vent is clean but I've yet to crack open the dryer to see what needs cleaning. Curious if the above symptoms are indicative of anything failing or needing cleaning?
    somegeek
    Make sure the heating element is not grounded or grounding out to the frame and staying on...
    Grounded elements on electric dryers, low heat complaints, poor heat complaints, what to look for in a broken element in a dryer
    If your lint filter is on top read #18 here for take-apart help:
    Inglis-Whirlpool-Kenmore dryers, common repair problems, idler pulleys, belt, drum rollers, noises, how to take apart, no heat problems, replacing the drum rollers, replacing the heating element, motor problems
    If the lint filter is in the door read #20
    Unplug your dryer first!
    May 2010
    Wa
    This thing is dead now with regards to running without the button being depressed. Now it only runs while the button is depressed.
    I popped off the control panel (after unplugging the dryer) and found this...
    The traces on the backside of the board aren't doing so well either...
    The caps are both swollen on the end cap as well.
    somegeek
    May 2010
    Wa
    Yeah - I'd say that resistor is part of the problem... I just pressed on it and heard a light crunching sound and it fell off the PCB. I need to make a few calls in the morning.
    Apr 2009
    you'd be better off to replace the whole PCB,, as other parts may be dfectiv but you can't see it,, Jake will link you to the new part
    May 2010
    Wa
    Yeah - I went ahead and ordered Part No 1378522(to replace original part number is 3976633). Thanks.
    Yup, thats the problem.
    Look here, from NoTalent in 2005:
    Here's the new control board for your model:
    Manufacturer part number W10116565 is RepairClinic item number 1378522
    W10116565
    Oct 2007
    FT Worth, TX
    Jake, Not intending to hijack this thread, but here is a pic of the board I replaced.
    Yes, I know.
  1. Kenmore Dryer 417.94072301 No Heat
    By brimmyhop in forum Sears Kenmore
    Last Post: September 29th, 2008, 12:46 AM
  2. Whirpool Dryer wont run continuously and wont heat.
    By Analog-X in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 30th, 2008, 06:47 AM
  3. Duet Dryer stops drying after 15 minutes
    By wrobins in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 14th, 2007, 03:10 PM
  4. Replies: 1
    Last Post: December 26th, 2006, 11:40 PM
  5. Replies: 3
    Last Post: December 10th, 2005, 05:07 PM
