Results 1 to 10 of 12
Thread: Fridge is not blowing cold air when freezer door close
    May 2010
    Baton Rouge, LA
    Default Fridge is not blowing cold air when freezer door close
    Model Number: KSRS27ILSS13
    Brand: KitchenAid
    Hello,
    My freezer is working fine. However, my fridge side is not very cold. I noticed fridge is not blowing out cold air through the vent on the top left. If I open the freezer door, I can feel the cold air then blowing through the vent, but if I closed the freezer door, no air is coming out. What is the problem? Please someone help or any suggestion would be appreciated.
    Yes,
    Usually when you open your freezer door and the air flows good into your refrigerator section, then you close the freezer door and it stops flowing good, that indicates an ice clog in your return air duct tunnel assembly.
    #4 here is your return air duct louver that unsnaps:
    (click to enlarge)
    Its on the the left side wall in your refrigerator section, so you will likely need to remove the middle shelves and lower drawers to access it.
    Clear all the ice out and see if that solves it. You can run hot water down and see if it flows out from the bottom vent, take the shelves out of the freezer, then take the lower back panel off from inside the freezer, then you can see the bottom vent to the right.
    Also look at all the evaporator coils, if those coils are blocked with excessive frost that will cause this issue as well.
    Pull off your air duct#5, just unsnaps. to make it easier to get that lower back access panel#17 off: Air Flow parts for Whirlpool KSRS27ILSS13 - AppliancePartsPros.com
    May 2010
    Baton Rouge, LA
    Thanks Jack for the reply, I'll give that a try see if resolve the problem.
    May 2010
    Baton Rouge, LA
    [IMG]file:///C:/Users/JoeVu/Pictures/2010-05-28/112.JPG[/IMG]
    When you said "run hot water down", where am I running the water? Is it the vent from middle of the refrigerator side you are talking about?
    Where is the evaporator coil? In the outside and in the back of the refrigerator?
    Update 1: I took the cover in the back of the freezer out, it look like the bottom 2 coils are covered with ice, not sure why it does that?
    May 2010
    Baton Rouge, LA
    Update 3: I took the back panel in the freezer out, defrost the evaporator coil, run some water from the bottom vent of the fridge to the freezer side to clear out the ice clog up in there.
    After all that is done, now I can feel the air going out to the top vent of the fridge even the freezer door is closed. That's a good sign. I think it solved my problem, if not I'll be back to update more.
    Thanks for you help Jack.
    Excellent, good job, sounds like you got it.
    May 2010
    Baton Rouge, LA
    Update:
    After I clear the air duct return vent, everything is really cooling and especially the fridge side it get very cold, too cold to be exact. I have to adjust the temp on the fridge side to the highest which is 41F and it's still freezing.
    Also after about a month, the freezer side started to build up ice and block the duct return vent again. How can I solve the problem without having to defrost the refrigerator every 2 week or so?
    thanks
    Which duct is blocked with ice?
    May 2010
    Baton Rouge, LA
    there is ice deposit at the bottom shelf in the freezer, ice is all over the middle back pane in the freezer, and now ice is blocking the top vent. The fridge is so cold that everything in the fridge is icy.
    Ok, I really don't know why its doing all this, you likely need to have KitchenAid come out, this one has me stumped. Your having way to many problems with this than I've ever seen before.
  1. GE Fridge not blowing cold air in fridge and freezer
    By ghostman126 in forum GE/Hotpoint
    Last Post: March 23rd, 2013, 10:41 PM
  2. Replies: 5
    Last Post: November 28th, 2012, 03:50 PM
  3. Replies: 10
    Last Post: July 26th, 2012, 08:39 AM
  4. Replies: 1
    Last Post: October 30th, 2011, 06:49 AM
  5. Whirlpool fridge and freezer not blowing cold.
    By Joefp in forum Whirlpool/Roper/Estate
    Last Post: November 29th, 2007, 05:36 PM
