Results 1 to 4 of 4
Thread: Dryer Squeaks
    Nov 2005
    Massillon
    Default Dryer Squeaks
    I have a GE electic dryer model# DDE7900SBLWW & it has started to make a annoying squeaking sound while drying. The drum still spins & it is still drying clothes.
    Anyone have some ideas on what may be causing this?
    Thanks in advance...
    The common noise issues i usually see on the GE's are the rear drum shaft bushing and the front drum glide pad assembly worn out.
    Jeff1 has a good section on the GE's here:
    http://www.applianceaid.com/ge-dryers.html
    Nov 2005
    Massillon
    Jake:
    You are correct, that seems to be where the noise is coming from. I did spray some WD40 on that area & it went away for a few loads, but has returned. I figured it would, but at least I found the problem.
    Thanks for your reply!!
    Glad you found the problem,
    Thanks for the update,
  1. maytag dryer squeaks when running
    By fixerdoug in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 29th, 2007, 11:00 AM
  2. Dryer Squeaks All The Time.....
    By FRANK RIZZO in forum Frigidaire/Electrolux
    Last Post: March 6th, 2007, 12:01 PM
  3. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    By jnicosia in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 19th, 2005, 10:48 PM
  4. Kitchen Aid KGYS700GQ1 dryer squeaks
    By jcoon in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 17th, 2005, 07:06 PM
  5. Kenmore 90 Series Gas Dryer Problem
    By HomeRepairGreenhorn in forum Sears Kenmore
    Last Post: March 15th, 2005, 03:02 PM
