Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Glasses on top rack do not get clean
    Jun 2010
    Columbus, OH
    Default Glasses on top rack do not get clean
    Model Number: FDB4315LFC0
    Brand: Frigidaire
    The top rack of glasses on my frigidaire 4000 series dishwasher do not always get clean. Many times there are small food particles inside the glasses. I have so far checked the following:
    1. Removed the filter from the bottom and cleaned it although it was not that dirty to begin with.
    2. Checked water temp at tap which is 135 degrees.
    3. Turned on tap before running dishwasher to ensure the water going into the it was already hot as soon as it starts.
    I also rinse the dishes before putting them in the dishwasher. One thing I have noticed is that after the tub fills up with water it never goes above the heating element. It is always an inch below no matter where in the cycle it is currently running. Could this be the problem? Maybe the dishwasher is not pulling in enough water?
    We need the complete model#, the model# tag is located inside the dishwasher on the top or side.
    No dishwashers ever have water level above the element, its always just under the element, so its likely your motor/pump assembly is bad.
    Jun 2010
    Columbus, OH
    Hi Jake,
    Model number is FDB4315LFC0.
    But check first for broken glass or seeds in the impeller:
    http://www.applianceaid.com/frigidaire-new.html#new
    Here's the motor/pump assembly for your model.
    In stock here:
    Manufacturer part number 154793001 is RepairClinic item number 1557823
    Jun 2010
    Columbus, OH
    I took out the bottom sprayer, filter, screen and then removed the three scews that hold the cover over the impeller. There was a little bit of crud in there but not much. There was no glass. The impeller itself seemed clean. I put it all back together and will run again soon. Not enough dirty dishes yet to run another cycle.
    One other thing I should mention is that when I took the three screws out to remove the cover over the impeller, there was 1 or 2 cups of water sitting in there. Not sure if that indicates anything.
    Thats fine about the water, its normal.
    Next time you run a cycle let us know how it does.
    Jun 2010
    Columbus, OH
    I ran another cycle. This time I used the hi-temp option. First time I have ever used that but it did not seem to make much of a difference. I'm still getting some small particles on a few glasses. I did open the door a couple of times during the cycle and noticed that the bottom sprayer was turning/spraying but the top spinner and spinner under the top rack were not. Is that normal depending on where it is in the cycle? Or should all of the sprayers be working when the bottom one is.
    Also could it just be my expectations of how clean the dishes should be are too high? Its not like the glasses are covered in dirt but some of them do have small specs of food or whatever on them and require me to manually clean them. Seems to me they should all come out perfectly clean?
    The upper one spins at different times than the lower.
    Of course they should come out clean, mine's over 10 years old and get as clean as the day I bought it.
    Clean is Clean, not leaving any particles behind.
    Jun 2010
    Columbus, OH
    Hi Jake,
    I forgot to update this. This problem is still not resolved but here it what has happened so far. I took the plate off the bottom and decided that replacing the pump/motor was a little beyond my ability so called the repairman instead. He noticed that the dishwasher was not getting enough water. I always suspected this too. Every time I checked the water level, it just seemed to be awfully low. The repairman decided to replace the water inlet valve. It turned out the old one had a lot of reside inside it. With the new inlet valve installed, the water level is now noticeably higher however the same problem still exists: dishes on the top rack are still not getting clean. I called the repair company back and they sent out a different repairman out this time. He said he has seen this problem before and that in order to fix it he has substituted a different inlet valve for the one spec'd on my Frigidaire. I'm not sure what model he is going to use but has ordered thet part and it should be in later this week. Hopefully this will do the trick. At least they aren;t charging me parts and labor for the second inlet valve. I'll let you know what happens.
    Thanks.
    Ok, I can see why the first tech changed the fill valve, but the 2nd tech. ordering a substitute valve doesn't make sense, I've never had to do that in my 20+ years of appliance repair.
    That likely won't solve it, the new motor/pump assembly likely would.
  1. Replies: 14
    Last Post: August 4th, 2011, 10:00 AM
  2. Replies: 5
    Last Post: December 2nd, 2009, 11:54 AM
  3. [FIXED] still wont clean the top rack!!!
    By jon z in forum KitchenAid
    Last Post: March 20th, 2009, 11:47 PM
  4. Replacing Top Rack Of Kuds220t
    By klinger in forum KitchenAid
    Last Post: July 31st, 2007, 01:22 AM
  5. Replies: 1
    Last Post: July 13th, 2005, 11:51 PM
